Leaky Break Reservoir - Page 3 - Defender Source
Old June 12th, 2016, 04:20 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
John, you're a genius. It worked.
Old June 12th, 2016, 04:32 PM
Cool that you got it fixed. My issue is usually pistons that wont push back into the calipers.
Old June 12th, 2016, 04:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The front driver unclogged but the rear passenger won't budge. 15 psi and I'm pumping the pedal. Still nothing. When the front unclogged I was able to floor the pedal with some resistance. With the rear it's very stiff and will not go down all the way. Any ideas as to what this indicates?
Old June 12th, 2016, 04:56 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I cracked the break line and confirmed there is pressure to the caliper. Must be clogged. Not responding to pumping so far.
Old June 12th, 2016, 05:10 PM
May be time for a new calliper...
Old June 12th, 2016, 05:17 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I got it! This time is was a clogged nipple. I depressurized and swapped the rear nipples then I was able to bleed. All done!
I certainly will do it every two years from now on. In fact if I ever get to putting a new chassis on I will do new break lines and calipers as well. Thanks everyone!
Old June 12th, 2016, 05:37 PM
When the time comes, you can put Defender 110 rear brakes n it.
Old June 12th, 2016, 05:58 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What's the difference? When the time comes I'm buying a 110
Old June 12th, 2016, 08:01 PM
The pads, rotors, and callipers are all bigger and fit with no modifications.
Old June 12th, 2016, 08:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Huh, good to know. Will they fit in front as well?
Old June 12th, 2016, 08:22 PM
Pretty sure a NAS 90 like all later 90s use the same front brakes as 110s. They use the smaller rears as that makes sense to not over bias the rears.
Old June 13th, 2016, 06:48 AM
If I slam my brakes the fronts are still the ones that lock up, not the rears, so it seems pretty balanced. I don't think they are big enough that the rears will be over biased. I've only had them on for ~5k miles, but after some time I will see if the rears are wearing out more quickly than the fronts.
Old June 13th, 2016, 08:36 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The 90 has a pressure reducing valve for the rear brakes. The 110 doesn't. This valve is what keeps reduced pressure on the rear brakes. I can only assume therefore that it would be fine to switch to 110 brakes but I would do all fours and not just the rear so as to keep it balanced.
Old June 13th, 2016, 08:57 AM
You can get a rear line proportioning valve that has manual adjustment. That's what I put on the 109.
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
leaky/bad '97 D90 Radiator kiphartzell Wanted 8 April 11th, 2005 03:42 PM
Leaky windows - 97 D-90SW BarryO Defender Technical Discussions 6 April 2nd, 2004 07:39 PM
