Leaky AC - Defender Source
Old August 12th, 2012, 10:26 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Leaky AC
Shockingly it was warm enough today in Seattle for me to turn on the AC for the first time since I bought the truck. It seemed to work and cool well but left maybe 1/4 cup of water on the passenger side floormat. Normal operation, or something I need to fix?
Old August 12th, 2012, 10:33 PM
Blocked drain tube ... It's on left hand side of passenger footwell and should drain out under the truck ... Remove trim and give it a clean.
Old August 13th, 2012, 01:10 AM
brettm's Avatar
brettm
Brett
sounds simple enough even i could fix it - thanks jason.
ac
AC clutch not engaging (94 D-90) down_shift Defender Technical Discussions 16 August 25th, 2012 04:27 AM
Leaky AC quesion? okyrover Defender Technical Discussions 5 February 14th, 2011 09:02 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Leaky windows - 97 D-90SW BarryO Defender Technical Discussions 6 April 2nd, 2004 07:39 PM
