Leaks - D90 Wagon - Defender Source
Old November 24th, 2004, 06:18 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Question Leaks - D90 Wagon
Searched re leaks - did not find much.
Just got in from a pouring rain - I mean really pouring.
I replaced the vent seals and adjusted the vent handles so no leaks there.
However, water is geting in at the base of my doors - my new carpet sections are getting wet! :o
Further, water leaked in behind the seats at the seat belt area(s). on one side (driver) in the rear the carpet (very corners) is wet at the front and rear jump seats. Water leaking in at slide window and running down channel?
I have already bought new bottom seals for the doors - pending install - but has anyone run into these leaks?
Should I expect some of them :o
Any experiences / corrections appreciated
Cheers!
Old November 24th, 2004, 07:43 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Defenders never, ever leak. If you have a leak return the truck immediately.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 24th, 2004, 07:57 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
Leaks are sort of normal, but that does sound excessive. I get some from my sunroof, which probably just needs to be cleaned off a bit, and then I'm thinking from the roll bar on the drivers side, as occasionally water runs down the door from behind the headliner... I'll get to it, some day ;-)
Old November 24th, 2004, 08:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Mine leaks constantly too. Oddly enough, the sunroof on mine appears to have a different curve to it than the top. Wierd.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 24th, 2004, 08:49 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
SW's have it easy when it comes to leaks! I look at it as a way of washing the inside.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old November 25th, 2004, 02:33 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
I don't know about the door leaks. However, in the rainy season, it seems water drips in every time I open the door, so maybe that why your carpet is getting wet.
I get the seat belt leak too - very annoying. It appears water leaks in, and ends up dripping down off the bolt immediately above the rolled-up, retracted belt. This ends up soaking the belt. I got the wet rear carpet as well.
I think all of this comes from leaks at the bottom of the back side windows. I haven't completely diagnosed it, which I think will involve removing the liner in the back, which requires removing the seats.
Yea, you're not going to get much sympathy from ST owners. But they don't have to worry about carpeting getting moldy, either.
Old November 27th, 2004, 08:28 PM
If you inbox can handle it, I can send you a 4.1 meg water infiltration hadbook which is unconveniently written in German. However, it has lots of excellent explanatory diagrams to help eliminate water intrusion into the defender. Just let me know if you want it.
Old November 27th, 2004, 09:59 PM
would you mind sending that my way also???
Old November 28th, 2004, 07:06 PM
too easy. Tonight or tomorrow depending on when I unpack the computer with the file.
Old November 29th, 2004, 03:28 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
If you would be so kind, please send it my way as well, at your convenience. 'guess its time to see how much of that 2 years of high school German I've forgotten.
Old November 29th, 2004, 08:23 AM
mspell
Michael Spellman
I'd love to see that as well. Altavista babelfish will help translate...
Old November 29th, 2004, 09:32 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Jim, Can you send that my way as well?
eric dot siepmann at gmail dot com?
EwS
Old November 29th, 2004, 11:41 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
one more name to your list, please: cdavis (at) thelightingagency (dot) com
Old November 29th, 2004, 01:24 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Jim, another if you will - jmccoy@agwatertechnologies.com
Thanks!
"It's not a Jeep"
Old November 29th, 2004, 01:59 PM
Ok, I sent an inbox bomb to all who requested it.
If you didnt get it then your account bounced it or your name is BarryO and you chose not to make your email address visibile to other members
Old November 29th, 2004, 02:21 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Ok, like Brian said, us ST guys don't want to hear any complaints about leaks!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old November 29th, 2004, 10:47 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Yes, Jim Please send to me as well!
I have traced some leaks down by using 1- the "flashlight in the dark" method and 2- the trusty old water hose
It seems , though I had thought the rear leaks might be at the sliders, it is actually the seal where the top cap meets the body (below the windows). While no light shows (1), water does dribble into the interior in several places if you keep it running on the side area for a bit and watch with a flashlight very closely.
Also I noticed gaps on the roof at the seams which I feel may be allowing some leaks as well possibly dripping onto the headliner and running down.
I used some white silicone to seal the roof seams especially on the arched area above where to roll bolts in.
NOTE: By using masking tape to control the application area I was able to seal the seams without the mess. Nice clean caulk only inside the seams.
To avoid removing the top, at least for now, I intend to use the same method to control the application of butyl rubber sealer inside the roof cap/body seams as well.
I believe the door leaks will be corrected by adjusting the doors and replacing the bottom door seals but I will post upon completion of same.
Thanks for the replys!
Old November 29th, 2004, 11:29 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Jim,
Please send it my way as well.
thanks,
Abel Villesca
abel.villesca@comcast.net
Old November 30th, 2004, 11:44 AM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Thanks Jim for the "book" - if I could just read German However, "a picture is worth a thousand words" . .
These are the areas I had already addressed first (images from manual attached)
But it seems that it might be better to just seal the entire area where the cap meets the lower body. I would rather change the seal to new but, again, will prob just seal with Butyl for now. It is leaking at points at the front and rear of the cap for sure. Seal prob dry and brittle re age.
ID:	1961   Click image for larger version
Old December 1st, 2004, 01:16 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
OK, I changed my email settings!
90, d90
Parting '97 D90 Station Wagon charles kellogg The Vendors Loft 13 May 30th, 2007 03:11 AM
Long Shot - Trade e320 wagon for D90 uzj100 For Sale - Vehicles 2 November 22nd, 2005 03:07 PM
1997 D90 Wagon $32,500 obo hayser For Sale - Vehicles 0 November 16th, 2005 06:54 PM
Opinion on a high milage D90 Wagon jsilverman Defender Technical Discussions 4 November 10th, 2005 10:12 AM
95 D90 Station Wagon Doors White. Richard Dekkard For Sale - Parts 4 April 17th, 2005 05:15 PM
