Leaking water from the back of the cylinder head - Defender Source
Old December 5th, 2013, 06:41 AM
fmrodrigues
Frederico
2000 Defender 90 SW
Hello to all,
This is probably covered in the forum but I simply canít find it.
My 110 TD5, with 180.000 KM, is leaking water from the back of the cylinder head.
Iíve took some photos just to illustrate, and from the parts catalogue I can see itís the Plug Core Ė 37D2260L.
The questions I have are:
Is this normal with this KM?
Can it be replaced without taking the head off?
(what do I need to replace it)
Does this mean thereís also a problem with the head gasket?
Ö
Thanks in advanced.
Regards
Frederico
Name:	110 water leak.JPG
ID:	85364   Click image for larger version
Name:	110 water leak 2.JPG
Old December 5th, 2013, 09:58 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Could it be the rocker panel gasket?
Old December 9th, 2013, 10:19 AM
fmrodrigues
Frederico
2000 Defender 90 SW
I’m sure it’s from the plug.
Does anybody know if there’s any product, like a sealant, we can apply from the outside to simply stop the water from leaking?
Regards
Frederico
Old December 9th, 2013, 10:25 PM
robisonservice
John Robison
2008 Supercharged Range Rover
Any sealant that can plug the leak from outside is likely to plug the heater core or radiator, or worse. Sorry.
Old December 9th, 2013, 11:58 PM
You could try a coolant "stop leak" but those are only temporary and can plug heater cores "bars leaks" brand is my preference and is not supposed to clog heater cores, but I still wouldn't rely on it for long term service.
Better bet would be a rubber expansion plug. And a spare one in the cubby.
But the only real fix is to pull the head and change the plug.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old December 10th, 2013, 05:56 AM
fmrodrigues
Frederico
2000 Defender 90 SW
Thanks to both,
I’ll definitely go for the plug change.
Can it be done without removing the head?
What kind of sealant must be applied to the new plug?
Regards
Frederico
Old December 10th, 2013, 07:45 AM
That's a freeze plug. It's probably rotting. Get a replacement.
Old December 10th, 2013, 02:52 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The plug swap itself is no that hard, it's the location that makes it really difficult.
- Charles Eames
Old December 11th, 2013, 09:00 AM
CDNRover's Avatar
CDNRover
Jeff Labbť
110 Ex-Mod FFR 200tdi
Replace the frost plug with new one. If you were stuck in the bush I would recommand PRC. It's an aircraft product like silicone with extra strength. Used it over water, gaz, diesel or what ever. It's a bitch to remove! But if you can repair it properly, why get to all this trouble?
My two cents..
ac, water
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Water from under dash tmore Defender Technical Discussions 13 September 29th, 2004 02:43 AM
Back Door Rattle mdmccallum Defender Technical Discussions 7 December 19th, 2003 12:55 PM
