leaking pistol oiler! I hate these things! - Defender Source
Old September 24th, 2006, 10:40 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I need help, and if you are confused as to where on your truck your pistol oiler is, it is not. It is in your garage, and if it is anything like mine, it has oil leaks all over my counters and mill. I use pistol oilers for my air tools, for cutting oil and the like and every one of them for the last 10 years leaked. Drives me F-N nuts. There has got to be someone out there that can tell me where to get a decent oiler that won't leak. I don't care if it is a straight solid nozzle or a bendable type--actually, I have a couple of each.
So help me, D-90, to PIMP MY GARAGE! Well, how about an oiler, at least!
Thanks!
Old September 24th, 2006, 11:28 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
http://www.garrettwade.com/shopping/...oductID=106381
I like to keep thing simple. Try one of these. Fill as needed and travel very well.
EwS
Old September 24th, 2006, 03:20 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Those look good for small tasks, but I need a lot more flow for cutting oils. I may just pick up a trio of those as well.
Anyone have a good bigger one?
Old September 26th, 2006, 11:19 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Any other suggestions?
Old September 26th, 2006, 12:09 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Here's an idea for you Chris. I have bandsaws at work we use to cut steel. They all come with a cutting fluid pump system. There's a reservoir with a pump and a hose that travels to a nozzle where the cutting is done.
If you're interested I could scavenge one (we only cut dry). I don't know if your mill has a fluid collection system, but many do. It shouldn't be that hard to adapt.
Old September 28th, 2006, 12:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Rod, thanks for the offer--I might take you up on that. I will give it some thought if I could actually use it--my mill is small and that sure could save some edges! Thanks.
Old September 28th, 2006, 12:32 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Search in google for a product called MQL. Its sold in Europe now but can be had here. Stands for Minimum Quantity Liquid. It has the highest lubricity of any liquid substance on earth. One little spray of that is all you need. Then you can throw all your oil and mess away. I have seen this work and trust me, it rocks.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Fox shocks leaking... AggieD90 Defender Technical Discussions 9 March 19th, 2006 01:32 PM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
Leaking... mattwhite Defender Technical Discussions 2 March 29th, 2004 09:53 AM
intake manifold leaking JRowe Defender Technical Discussions 8 February 9th, 2004 05:02 PM
Things to look for in a NAS D-90 rayblake Defender Technical Discussions 10 November 14th, 2003 01:43 PM
