Leaking grease seal - Defender Source
Old September 17th, 2006, 11:18 AM
Rover- Girl
Guest
Posts: n/a
Question Leaking grease seal
The R front grease seal has been leaking for a few weeks now.
Want to wait to have it fixed until the next service is due on Nov 15th.
I will also have the tires rotated & balanced (thats why I wanna wait and just have it fixed then).
I was just wondering if it is ok to drive like this, or would that do more damage.
FYI..I have not driven it hart or off road since it started to leak...just run it back and forth to work.
Thanks for the heads up....
Old September 18th, 2006, 02:03 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Do you mean the swivel housing? (shiny round part of your axle that allows truck to steer)
grease is leaking out of this?
regardless, if something has been leaking for a few weeks and you have a few more to go, then the level is low and you should add appropriate fluids. Its probably been leaking since before you noticed it. I dont think the grease in the swivels can leak unless something is majorly loose. Or unless the gear oil is getting into the swivels, and something is loose.
check for any loose bolts. get a wrench and try to tighten things. Add oil or grease. you cant overfill these things to the point of damage like an engine, so you might as well get to know your rover that much more and lube 'er up!
post pix if you want REAL help!
~Steve
Old September 18th, 2006, 04:11 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Do you mean a lot of leaking... previous poster whas right if grease is leaking you have a problem... If it is oil and it is just leaking a bit... that is fine. Mine leak like hell but I just over fill them and keep an eye on the level. sure you can replace the seal but if they jsut started leaing oil you have a long way to go before it is a problem... just keep it full. speaking of which I really need to do this soon
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
leaking grease jimmy salmon Defender Technical Discussions 16 January 11th, 2007 09:55 PM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
