leaking grease - Defender Source
Old April 27th, 2006, 10:31 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
leaking grease
i have grease weeping through where the half axle comes through the drive member and spraying over the front wheel, every thing is assembled right, how do i stop it (other than take out all the grease)
3rd low and BOOT IT
Old April 27th, 2006, 10:34 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Do you mean from the swivel ball seal?
Old April 27th, 2006, 10:47 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
on the outside where the rubber dust cap is
3rd low and BOOT IT
Old April 27th, 2006, 11:04 AM
Is it only grease or grease and oil? If the inner seal is backward (the one on the inside wheel bearing) gear oil from the axle will mix with the wheel bearing grease and make a mess. It may also leak out onto the break rotor and spray all over that stuff too.
Old April 27th, 2006, 11:10 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
pull the cap clean it well & seal it w/ hylo
Old April 27th, 2006, 11:16 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
only leaking on the out side,just been to look, i have a small rip in the hub cap where the grease is leaking through. new cap $2.80, super glue $5 no shipping on the glue
3rd low and BOOT IT
Old April 27th, 2006, 11:23 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
If you use super glue!
Old January 9th, 2007, 10:23 PM
Clarification question on this. I now have grease seeping out of one of my rear hub dust caps on my NAS 110. That dust cap has a tear in it. replacement ordered and on the way. Does the rubber dust cap actually keep in grease/oil, and therefore the tear is causing the problem, or is another seal internally supposed to keep it all in, preventing grease from getting into the dust cap, and therefore indicating that the problem is larger than just replacing the dust cap?
Old January 10th, 2007, 01:08 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Just FYI, I have a couple of these covers new in the plastic that anyone is welcome to. I got rid of the seal all together. It has to be one of the dumbest designs out there.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 10th, 2007, 07:59 AM
robisonservice
John Robison
2008 Supercharged Range Rover
No one seems to have mentioned the underlying cause . . if I may assume the cap is the same as always, and nothing is visibly different . . . then the reason grease started coming out is almost certainly that the inner axle seal has failed and gear oil is now melting the grease, and the liquified grease comes out where the formerly solid grease did not.
Old January 10th, 2007, 09:56 AM
Monkeyboy
Guest
Posts: n/a
Ok, so there's more gear lube where we expect the wheel bearing grease to live by itself ... if we can keep the gear lube / grease soup inside the hub, what's the problem???
(Yes, I'm considering sealing up the rubber "hubcap" like the metal ones on the Series)
KAA - no inner axles seals on the Disco for years now ...
Old January 10th, 2007, 11:21 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I have run all my early coil sprung stuff with no inner axle seal for years since it worked so well on my 1988 RRC 250+K never needed wheel bearings. I'm not a engineer but if it works why did they try to "fix" it.
Eric
Old January 10th, 2007, 04:39 PM
robisonservice
John Robison
Eric
When you modify a Rover with wider wheels, offset, big tires . . . you increase the load on the bearings. The strength of the system is reduced if there is no inner seal and they run in oil. So you are working it harder, and it's weaker.
That's the answer to "why fix it?"
Old January 10th, 2007, 04:50 PM
Monkeyboy
Guest
Posts: n/a
Whoa big fella'
I don't know about Eric, but I'm not about to go with any (significant) changes in offset other than those provided by LR wheels (from time to time the Disco wears the NATO steel wheels) ... and the 265/75 (on the D90) or 235/85 (on the Disco) size is plenty of tire for me too.
There are 143k miles on the Disco and only ~50k on the D90 and I've had to change one rear wheel bearing (on the Disco) that was water / mud contaminated by a bad hub seal ... seems like entirely reasonable life expectancy to me, given their periodic exposure to less that ideal conditions.
Oops, I'm a liar. I did replace bearings when I changed the rotors on the Disco. Still, plenty of reliability for me.
Awaiting enlightenment...
KAA
Old January 10th, 2007, 05:35 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I disagree with this on the basis that most all of the heavy equipment and larger trucks and forklifts that I have worked on utilized wet bearings in a fully floating axle application. I don't see eliminating the inner seals and running wet bearings as weakening anything. I have run my Defender this way for the last 100K miles. The only real problem encountered WRT doing this on a Land Rover is the potential for leaks. Land Rover offers a double lip hub seal that will effectively seal 90wt into the hubs. It is p/n RTC3511 and is a drop in replacement for the FTC4785. You just have to follow the directions printed on the seal and seat it to a depth of 3mm below flush to allow room for the extra lip. As far as the rubber drive flange cap...you might look at the cap from a NAS or earlier D110...they were more robust and fit tighter. Keith at Rover Tracks tells me the galvanized Series rover caps will fit, too...but I haven't tried it.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 11th, 2007, 06:09 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Story I heard was that LR didn't think the US would want the oil leaking out on drive ways. Series and early 90 & 110 had oil lubed wheel bearings.
Either the dust cap has split, the sealing surface has got mud or something in it or the axle breather is blocked to let the oil out.
OR
Your wheel is anout to fall off
Probably not the last thing but it pays to check
Didn't you get rid of the whole axle
Mike Hammond
Old January 11th, 2007, 09:55 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Didn't you get rid of the whole axle [/QUOTE]
In the rear I have the hub and spindle of a rover modified to run a full floating axle with a 9in center. I took cut-outs of steel and welded them on the end of the drive flange so I could dump the little rubber pieces. So I have a few extra if anyone wants them.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Leaking grease seal Rover- Girl Defender Technical Discussions 2 September 18th, 2006 04:11 PM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
Leaking... mattwhite Defender Technical Discussions 2 March 29th, 2004 09:53 AM
intake manifold leaking JRowe Defender Technical Discussions 8 February 9th, 2004 05:02 PM
