Leaking fuel - Defender Source
Old June 16th, 2011, 11:04 PM
atpick's Avatar
atpick
Andy
1990 110
Leaking fuel
Drove the Defender about 50 miles yesterday, filled the tank completely up, which I rarely do, come out this morning to fuel dripping from what I believe is the "fuel tank level reader"...or is it the fuel pump. Any idea what part I need to replace to fix this? First time I have seen this, could it be from the 104 degree heat?
Name:	2011-06-16 07.17.01.jpg
ID:	39722   Click image for larger version
Name:	2011-06-16 17.28.23.jpg
Old June 17th, 2011, 07:38 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Looks like the fitting is leaking. It's a compression fitting with an olive. You can get new olives from any hardware store, they're a standard size.
Be CAREFUL loosening the fitting. Some of the pickups have a plastic pipe, and it's fragile. Others have metal and they are usually rusty and weak.
Tony
1984 110 "Smokey" (sold)
fuel
