Leaking Diff Fluid from Cap - Defender Source
Old October 27th, 2014, 02:02 PM
spammer
Samdford Wallace
95 RRC LWB / 86 Tithnous
I went off roading a few weeks ago and a rock crunched the center plastic cap on my wolf wheels. Now diff fluid is leaking out of the hole as I wait for the replacement cap to come in the mail.
My question is if there is another problem besides the plastic cap? If diff fluid is leaking out of the cap does that mean a seal is gone somewhere inside the wheel?
This is for a rear salisbury diff.
Old October 27th, 2014, 02:06 PM
spammer
Samdford Wallace
Ok cool. I did clear the breather a few months ago so I don't think that is the issue. Wasn't sure if they were supposed to leak without the cap or not. Thanks.
That depends....on the year of the axle. Later axles had seals on the axleshafts, earlier ones did not. Regardless, it is better to not have that seal and allow the diff oil to get to the shaft splines and hub bearings.
You should always carry a spare of the plastic caps. They are very cheap.
Old October 27th, 2014, 02:07 PM
I assume you are not driving it with the cap broken? As you will get dirt into the bearings.
Old October 27th, 2014, 02:10 PM
spammer
Samdford Wallace
I gobbed it with silicone to get home, which was a long long drive unfortunately. It made a mess of my wheel on the way home so it wasn't totally sealed. Now I have two spares coming in the mail. Lesson learned.
Leaking clutch fluid aclarke Defender Technical Discussions 27 December 9th, 2013 09:32 PM
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
transmission fluid leaking TravelerBT Misc. Chit-Chat 4 December 6th, 2008 09:02 PM
passenger axle leaking fluid cdb Defender Technical Discussions 7 March 21st, 2008 01:17 PM
diesel leaking from filler cap artm Defender Technical Discussions 2 December 4th, 2004 05:59 PM
