Leaking diff cover on salsbury - Defender Source
Old July 1st, 2009, 08:45 AM
turbodave
Dave C
1983 110
After changing the pinion seal for a DANA 60 unit, I now realise some oil was leaking from the diff cover seal. Is this meant to be a gasket, or RTV? If it is a gasket - is this also the same as a Dana 60 - or is it a LR specific part?
Old July 1st, 2009, 09:56 AM
GYM's Avatar
GYM
Gary
97 SW
Assuming the LR application is the same - the Dana 60 in my GTX uses a gasket. I got my last one through Year One.
Old July 1st, 2009, 10:55 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I would use "The Right Stuff"
Old July 6th, 2009, 01:37 PM
turbodave
Dave C
1983 110
So, I can confirm that a gasket from a 10-bolt Dana 60 is the same pattern. $5.20 at my local auto store - a lot cheaper than LR prices!!!
Old July 6th, 2009, 01:52 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Dana 60 and Salisbury same bolt patern. Just use what ever good quality gasket maker you usually use.
Pat
Kirk Lazarus, Tropic Thunder
Old July 6th, 2009, 03:10 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I changed all my salisbury axles to Solid Dana 60 covers. Nice and rock proof. They use RTV to seal.
cover
Salisbury Diff Cover Bolts - ARB Diff Cover Shearpin Smaller Projects 4 February 20th, 2008 03:52 PM
Salsbury Rear Diff Cover roverboy Wanted 9 April 6th, 2006 11:12 AM
110 Salisbury Diff cover AaronOwens Wanted 2 November 8th, 2005 01:34 PM
rear diff cover cracked, replacement ? artm Defender Technical Discussions 4 September 9th, 2005 12:00 PM
Sewer pipe cap diff cover writeup mudrover Defender Technical Discussions 7 August 29th, 2005 11:39 PM
