leaking diesel injectors - Defender Source
Old July 17th, 2008, 08:34 AM
seaswood
Diesel
Does anyone have any knowledge on torque to line in fuel injector on 2.5 na diesel?
Had injectors rebuilt reinstalled & there is a small amount of weepage on 3 of 4 injectors?
This is not much but I assume there should be no weepage?
I did post this with another post & decided to post separate.
Old July 17th, 2008, 11:01 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Loosen and retighten with a good quaility wrench or flare style wrench . There is no torque spec. Tighten until no leaks.
It is possible you may have to dress the metal line end with sandpaper carefully if it has a buildup of crap on it.
Good luck
legend in my own mind
Old July 17th, 2008, 03:32 PM
seaswood
Diesel
diesel injectors
Thanks i did try dressing the line in & will see how it weeps in the morn.
was able to bleed to top of filter but not up the line to injector.
Old July 17th, 2008, 04:31 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Whats the problem? Are you having problems starting it after changing filters?
Old July 17th, 2008, 07:14 PM
seaswood
Diesel
diesel injectors
Just had injectors rebuilt well over winter i was away.
& newly rebuilt injectors install was leaking.
Hopefully the sanding the piping clean will help.
Yes priming is a pina
Thanx
Old July 18th, 2008, 07:49 PM
seaswood
Diesel
Smile Diesel
Pendy Thanks either the betta wrench or sanding seemed to seal it all.
[img]images/icons/icon7.gif[/img]
diesel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
diesel leaking from filler cap artm Defender Technical Discussions 2 December 4th, 2004 05:59 PM
