Leaking dash - 110 - Defender Source
Old March 21st, 2010, 07:57 PM
bjf's Avatar
bjf
barry f
94 ST #395
Leaking dash - 110
So the dash is leaking in the 110. Passenger side under speaker, where the top of the kick panel attaches. I assume it is AC/Heaterbox related.
Before it does some massive damage anyone got an idea?
Old March 22nd, 2010, 03:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
bump
Old March 22nd, 2010, 03:52 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Have you checked your vent seals? Was the truck exposed to rain? I think the majority of leaks come in from the vent seals. I have taken the heater box off the bulkhead and aside from the big square hole where the blower blows in warm air, the only other holes are the 3-4 holes where it attaches to the bulkhead. Does it look like green fluorescent radiator fluid? That may be your heater element leaking. I don't have an AC so can't comment on that.
MUDSUX
Old March 22nd, 2010, 04:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
no vents in the 110. bulkhead is solid. I assume it is coming from the heater box
Old March 22nd, 2010, 04:40 PM
Maybe wrap/tape up the box in plastic, then give it a good hosing down to verify the leak is really coming from there? I'm guessing there are a number of places i could be leaking in at still.
Old March 22nd, 2010, 04:50 PM
bjf's Avatar
bjf
barry f
94 ST #395
i have a feeling it is water leaking above where the heater box attaches to the bulkhead
Old March 22nd, 2010, 04:53 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
There's also a hole on the other side for the steering column. I am not sure about the NAS but my ROW bulkhead is ambidextrous. It has cutouts on the passenger side for the brake/clutch/accelerator boxes. It is simply covered with a blanking plate on the engine bay side.
MUDSUX
Old March 22nd, 2010, 05:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
pretty sure NAS trucks arent cut that way
Old March 22nd, 2010, 05:09 PM
Right so I'm suggesting you translate that feeling into fact. Tape it up above the heater box and see.
charles
Old March 22nd, 2010, 05:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
tape what up? in the engine bay? the thing is i am leaking without it ever raining so i assume it is the magic that goes on inside the heater/ac box
Old March 22nd, 2010, 05:19 PM
Aah, I was forgetting where you live. Most of us live places where it rains and rains regularly.
Your problem must be a/c condensation (inside) then. Locate the drain tube and make sure it's clear. I can't help you identify it other than it should be near the bottom of the box and probably runs out the firewall into the engine bay.
Old March 22nd, 2010, 05:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
yeah drain tube at bottom of the box is clear.
Old March 22nd, 2010, 05:43 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Is it connected?
Old March 22nd, 2010, 05:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
it just hangs off the bottom of the box
Old March 22nd, 2010, 06:23 PM
61rover's Avatar
61rover
John Crouse
My 110 leaked in the same spot and it was actually coming in along the door seal/post. I would check there as well. I think that's more likely than the heater.
Old March 22nd, 2010, 06:31 PM
Originally Posted by aosias View Post
Is it connected?
ROFL
Except he's claiming it's not due to rain and is too stubborn to just dry spray a hose on it and observe. So hard to tell what he's seeing and if this is truly not related to moisture outside the vehicle, what other sources of moisture are there inside other than condensation off the A/C?
Old March 22nd, 2010, 06:37 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
What about the winshield washer? Plastic tube cracked? Pump shorting out and running?--should eventually run out of fluid though.
MUDSUX
Old March 22nd, 2010, 06:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
new door seals. it is the same leak that caused a hole in bulkhead before that was fixed by last owner.
not coming from the doors as no rain.
110, dash
NAS 110 Dash Assembly / AC Bits Used FS SafariHP The Vendors Loft 0 March 15th, 2010 11:04 PM
early 110 dash wiring Abrooks Defender Technical Discussions 7 May 28th, 2008 04:34 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
