leaking d90 - Defender Source
Old November 18th, 2003, 10:30 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Hardtop leaking
Anyone have any suggestions on stopping a small leak along the top front( where it screws down) portion of the top. I have sealed all around the bolts and across the top with clear silicone. I still get some water dripping down through the map light.
Old November 18th, 2003, 10:40 AM
I had the same problem when I frist put my top on, I had to cover the entire bolt with kitchen and bath silicone, not the cheap stuff but the best stuff they had at HD. I also cleaned everything before I put the silicone on, that helped the most. I did not put anything over the top of the windshield exept weather stripping.
Old November 19th, 2003, 09:52 AM
Eric_S
Eric
'97 D-90 ST #1507
Rich,
I use what's called "cord weather-stripping", you can find it at most hardware stores.
http://builders-hardware.aubuchonha...trip-271225.asp
I just put a little bit under the washer and on the last few bolt threads and tighten away. Not only does it stop the leaks it has an added benefit of letting you know how much to tighten the bolt, i.e. once it starts to squeeze out that's usually tight enough. I also use it seal the gaps around the roll bars.
Hope this helps out.
Eric
Old November 21st, 2003, 08:15 AM
Campbell's Avatar
Campbell
Rich Campbell
leaking d90
I'm sure this will get some response. I have a 1994d90 with the fiberglass hardtop installed. I have used silicone around all the bolts and along the top seam. I am still getting a lot of water on the pass. floor. ANY ideas where it may be coming from. I have used a sh%t load of silicone in all the obvious locations.
Old November 21st, 2003, 08:20 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Have you checked the vents on the windscreen? This is a common place for leaking (mine do) and can be replaced by series 109 vent seals.
Old November 21st, 2003, 08:26 AM
Sometimes it is hard to get a good seal along the Doortop and bottom.
Old November 21st, 2003, 09:00 AM
mgrgpg
Mark
1989 D110
Door tops is a problem on mine...adjusted the hinges to put more pressure on the upper door area, and this has eliminated the passenger side leak, but I still have a small one on the driver side. I just added some weather stripping on the door top where there is a gap...have to see if this helps, have not had it out in the rain since I did this.
Mark
Old November 21st, 2003, 10:56 AM
Campbell's Avatar
Campbell
Rich Campbell
THANKS GUYS, I will check all those areas as well. In terms of the vent seals can you run some silicone on the outside without replacing the seals. I don't use them anyway.
Old November 25th, 2003, 05:05 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Toyota locked a cat into their car to test the seals. 24 hours later they came back and the cat had suffocated. Land Rover tried it, they came back 24 hours later and couldn't find the cat.
Mike Hammond
Old November 25th, 2003, 05:07 PM
mikeslandrover
Mike Hammond
Leaks go with the truck. How else will all the water get out after you've gone in too deep when wading?
Mike Hammond
Old May 12th, 2010, 12:21 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
I just tried the cord weather stripping & my hardtop is finally watertight! (except for one window seal, but I will address that later). I am thrilled to be driving in the rain & not have water pouring in!
90, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
