Leaking coolant problem - Defender Source
Old November 19th, 2010, 10:20 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I decided to remove and replace my horrible looking motor mounts. I jacked up the engine from the oil pan with some wood blocks to distribute the weight and all. At some point I must of loosened up or broke something in the coolant system. Now when the truck is sitting I have a slow leak of coolant. It doesn't appear to be coming from the radiator or the the fill cap. When the truck runs for a while and the engine heats up I see coolant leaking like a faucet. I just can't localize where it's coming from.
Any ideas what to look for?
Old November 20th, 2010, 01:25 AM
michael67's Avatar
michael67
Michael White
110 Tdi
How old are your coolant lines? You may just want to wholesale replace them if they're more than four or five years old. You may also want to check the coolant reservoir.
Old November 20th, 2010, 12:10 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Coolant lines are 3 years or a little older. I looked at the reservoir and didn't see any leaks. I'll have to order some new lines and see if that corrects the problem.
Old November 20th, 2010, 12:35 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Some places can also do leak testing using a dye and lamp setup that causes the fresh leak to glow.
Old November 20th, 2010, 12:37 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
You probably loosened the lower radiator hose / clamp while jacking the engine up. I did the exact same thing, visually inspect, adjust hose/clamp and you should be ok. That or put a new hose on just to be sure.
Robert Deniro
Old November 21st, 2010, 02:14 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I'll check the coolant hose in the morning. If that's not it I'll look for some place that can do a leak test.
Thanks for all the suggestions.
Old November 22nd, 2010, 09:17 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Michael and Neil
You both had it right. The one of the coolant lines looks a bit older then the rest. Must have not been changed out when I had work done on it. The line looks a bit worn and the hose clamps on a few were loose. But I did find the one responsible for the leak! Tightened down and I'll be ordering a fresh set of coolant lines and clamps so they all are in good working order.
Thanks for the help and diagnosis!
coolant
Coolant leaking into cylinder mystery jaherring Defender Technical Discussions 9 April 17th, 2007 07:55 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
