Leaking clutch fluid - Page 2 - Defender Source
Old December 9th, 2013, 10:05 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
I figured it has to be something with the transmission, so the first order of business is to drain the fluid and see what we see. Since I'm not doing the work myself as I'm a wimp in the winter, the shop guy did it this mornig. He said he took it for a drive this morning and it shifted fine but made a clunking sound when he took is foot off the accelerator. He drained the oil and said less than half a litre came out. Oops, I feel like an idiot now. I don't recall seeing a leak there, but I guess there must have been a slow one. There was a lot of metal on the plug, although I'm not sure how much is normal.
I'm having the guy put ATF in there as that's what they have. They said they haven't been able to source MTF94. I'm going to see if that "fixes" things. If so, I'll drain the fluid again and put in something that's better long-term. If there are still problems, I guess the tranmissions coming out, but I'll burn that bridge if I get to it.
1986 110 CSW 200tdi (
Old December 9th, 2013, 10:28 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Replacement transmission fluid did nothing, so the gearbox is coming out. I have nobody but myself to blame for this one. I was so busy doing other stuff on the vehicle that I neglected this aspect of basic preventive maintenance. There goes $1500 or so of my life savings. Lesson learned, or so I hope.
Old December 9th, 2013, 11:33 AM
Oh well. It will let you replace the whole clutch throwout assembly. It is full of limited life components...
What gearbox is in it? If LT77, what suffix?
Old December 9th, 2013, 11:36 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
I don't know. Is the serial number stamped on the gearbox housing? If so, I'll find out once it's out.
It's an '86, but I have a feeling the transmission was replaced at some point by a previous owner.
Old December 9th, 2013, 06:43 PM
fraser61's Avatar
fraser61
Fraser Gourlay
1986 D110 TUM 300Tdi
Originally Posted by aclarke View Post
I don't know. Is the serial number stamped on the gearbox housing? If so, I'll find out once it's out. It's an '86, but I have a feeling the transmission was replaced at some point by a previous owner.
I've just taken a good LT77 gearbox out of my truck, it's yours for free if you arrange collection. There's no warranty but it will get you moving. Let me know if your interested happy Christmas Fraser
Fras61
2008 RRS SC
1986 D110 Tithonus 300TDi RHD
1979 S3 Lightweight
2006 ZX-10R
Beauty is in the eye of the beholder, get it out with eye drops.
Old December 9th, 2013, 06:50 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Wow, well thank you either way! I'll get things out first, then consider my options over the next few days.
- Andrew.
Old December 9th, 2013, 07:25 PM
fraser61's Avatar
fraser61
Fraser Gourlay
No problem it has around 50,000 miles on it, out of my Tithonus, worked perfectly well before, I'm replacing it with a new R380. All it needs is to change out any seals, replace the diff lock switch and I'm sure you will get a lot more miles out of it. Just let me know my Zip is Texas 77450. Cheers Fraser
Fras61
2008 RRS SC
1979 S3 Lightweight
2006 ZX-10R
Old December 9th, 2013, 09:32 PM
Have a look. Anything less than a "G" or maybe and "F" is not worth putting behind a TDI. It is too much torque and you will kill it within a few years.
My suggestion is get a G or H LT77 or a stumpy R380.
clutch
dark grey clutch fluid? tomaco1 Defender Technical Discussions 8 February 19th, 2012 03:34 PM
Clutch Slave Master Fluid Mystery RickM Defender Technical Discussions 2 August 11th, 2010 06:19 PM
Mystery of the disappearing clutch fluid Trigger Defender Technical Discussions 4 January 5th, 2009 05:50 PM
transmission fluid leaking TravelerBT Misc. Chit-Chat 4 December 6th, 2008 09:02 PM
