Leaking Clutc Master Cylinder - Defender Source
Old April 11th, 2014, 07:07 AM
chuckc4
chuck b
Registered User
Clutch MC was dripping (down the clutch pedal), I added fluid. Clutch M C stopped leaking. Is this just my imagination playing tricks on me?
Old April 11th, 2014, 07:29 AM
No! It's time.
Mark Kellgren
KM4BOR
Old April 11th, 2014, 08:28 AM
rovertrader's Avatar
rovertrader
Dale
The sooner the better, as all that brake fluid will be puddled in the floor board....
Old April 11th, 2014, 10:47 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
there are a few good threads on R/R the master on this board depending upon if you are NAS or ROW, RHD/LHD.
It's a walk in the park if you're RHD, but still soak the bolts on the engine bay side of the bulkhead with penetrating oil in advance just to make sure it goes smoothly.
Old April 11th, 2014, 10:48 AM
chuckc4
chuck b
Registered User
OK, then new TWR (now made in China) or another suggestion?
Old April 11th, 2014, 10:51 AM
Buy a factory unit from Rovers North.
It's easier to spend a little extra and only have to swap it once.
Old April 11th, 2014, 11:25 AM
and then have the old one resleeved in brass!
Mark Kellgren
KM4BOR
master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Leaking water from the back of the cylinder head fmrodrigues Defender Technical Discussions 8 December 11th, 2013 09:00 AM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Coolant leaking into cylinder mystery jaherring Defender Technical Discussions 9 April 17th, 2007 07:55 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
