Leaking Axle seals? - Defender Source
Old May 29th, 2008, 10:08 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Leaking Axle seals?
Does this look like leaking axle seals? It is on both sides of the rear.
ID:	13683   Click image for larger version
Gary
Old May 29th, 2008, 10:11 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Could be, pull a wheel and see. Use the RTC3511 seals when you replace them and repack your bearings while you are in there.
Old May 29th, 2008, 10:40 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
check your axle breather to make sure its not clogged or the new seals my be old seals very fast
Old May 30th, 2008, 12:01 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Are the seals on the wheel end of the axle or near the 3rd member?
I found it. Its near the hub.
Old May 30th, 2008, 04:22 PM
Looks like brake dust and water to me . . . .
Old June 2nd, 2008, 12:12 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Man my breathers were packed full of dirt. It took me about 2 hrs to get the rear one cleared out. It would have been easier to just replace it. Oh well, that's done. Now I need to replace my seals.
Old June 2nd, 2008, 02:30 PM
outfield
Steve
1995 D-90 SW #351
Hi Gary,
My inner wheel bearing seal at the spindle was cracked and I had fluid leaking on the inner part of my aftermarket steel wheel. When was the last time your bearings were greased? This seal is replaced after removing the inner bearing and packing it with grease.
Old June 3rd, 2008, 10:54 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
I pulled the wheels and to my surprise ALL the bolts were loose! Not sure what happened but I tightened them up and it is leak free now.
Gary
Old June 4th, 2008, 09:58 AM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
I just did all of mine on both sides on the front...very dirty job...not impossible for the DIY. For sure it was a lot easier on the lift than if I had done it on the garage floor.
axle, seals
Misc. seals and other parts crown14 For Sale - Parts 2 March 4th, 2009 01:05 PM
passenger axle leaking fluid cdb Defender Technical Discussions 7 March 21st, 2008 01:17 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Anyone do this? Bowtracer Defender Technical Discussions 13 March 18th, 2005 02:32 AM
» Defender Registry
#310
wmatos1001
110
Mes788
Add your Defender
