leaking around wheels / hubs - Page 2 - Defender Source
Old August 10th, 2010, 10:40 PM
Just wanted to add that when checking for play in wheel bearings on the front axle, grab the wheel at 12 and 6 as described. if there is noticeable play, have someone stand on the brake pedal while you check again. This will lock the hub in place. Any remaining play is in the swivel pins and not the wheel bearings.
Old August 11th, 2010, 07:47 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Cool good to know. Thanks
My Rover doesn’t leak oil, she is marking her territory.
Old April 18th, 2011, 11:54 AM
muhley
matt
110 300 tdi
Where can I get the rtc 3511 seals. Is it something that has to be ordered on line from a land Rover specialist? I've called all of the parts chains and nobody has any record of that part existing.
Old April 18th, 2011, 12:35 PM
Naplm00
Matthew
rovers north will have them, or any LR dealer
Old April 18th, 2011, 01:18 PM
muhley
matt
110 300 tdi
they are a special order item from LR Miramar now, going to have to order on line.
wheel, wheels
Disco II / Range Rover Wheels rvrnut110 For Sale - Parts 0 November 9th, 2005 01:51 AM
35" BFG AT KOs and 15x7 wheels Jase For Sale - Parts 1 August 19th, 2005 05:30 PM
Bead-locks wheels for CHEAP! RedRhinoProducts For Sale - Parts 0 May 8th, 2005 11:35 PM
Astarli Steering Wheels and Hubs thelandroverguy Defender Technical Discussions 3 November 24th, 2004 02:30 PM
Steel wheels! TwisteD90 Wanted 0 November 2nd, 2004 02:11 PM
