Leaking A/C - Defender Source
Old May 23rd, 2004, 11:13 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Leaking A/C
Anyone here have any experience with a leaking air conditioner? I noticed a slight oily residue on the passenger footwell last fall. It was never very significant until over the winter, when the a/c wasn't used. By this point, the a/c was no longer cooling, and so I attributed the resulting mess to it. The dealer recently confirmed it had a leak somewhere. I held off on allowing them to piddle through at $85/hour after a few sour experiences.
When looking over the two coolant lines running through the firewall, one line has a build-up of the light colored oil. I've read through some of the other posts of work done on these units, but didn't run across this problem? Any help or suggestions is appreciated.
"Uhh...I think they all leak like that."
Old May 24th, 2004, 10:12 AM
I think the fluid is redish, I would just take it to a shop that works on AC systems, I really don't know to much about the system and I would not want to fool with the coolant in it.
Old May 24th, 2004, 10:26 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
That's the stuff, which eventually leaked out onto the floor. I hope it turns out to be nothing major.
Old May 24th, 2004, 10:40 AM
It may be just a bad hose, try and find whats leaking before you have someone work on it and tell them exactly what to fix or replace.
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
Possible sale of complete A/C Trigger For Sale - Parts 3 June 10th, 2005 02:36 AM
A/C unit Ray Bone Defender Technical Discussions 2 June 7th, 2005 06:46 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
