Leaking... - Defender Source
Old March 24th, 2004, 02:51 AM
mattwhite
Matt White
94 D-90
Leaking...
Unfortunately not in the usual places.
I'm leaking a lot of ATF fluid from the area between the power steering box and the drop arm. Would buying a new seal kit fix this problem?
Also since I'm college I have a limit number of tools to work with, however, I do have an impact wench, could I do it myself? What I mean is I don't want to have to remove half the parts from the steering box in a parking lot. A few nut and seals would be fine.
Matt
Old March 24th, 2004, 06:21 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
You can get a fluid you add to your atf that swells the seals in the box & stop it leaking. I think brake fluid does the same thing?
power steering stop leak
I would try this first, stripping them down with limited tools isn't easy & home reair is rarely succesfull unfortnately. Most people in the UK fit a new/recon when they leak.
Adwest is the company that manufactures the boxes & they sell direct over here (cheap as well)
adwest
Sniff my Diff ;)
Old March 29th, 2004, 09:53 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Matt, I agree with Brett, try the stop leak first. This same thing happened to my '95 Disco not long ago, unfortunately ended up replacing the steering box... I hope the stop leak works for you.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
leaking d90 Campbell Defender Technical Discussions 10 May 12th, 2010 12:21 PM
Fox shocks leaking... AggieD90 Defender Technical Discussions 9 March 19th, 2006 01:32 PM
diesel leaking from filler cap artm Defender Technical Discussions 2 December 4th, 2004 05:59 PM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
intake manifold leaking JRowe Defender Technical Discussions 8 February 9th, 2004 05:02 PM
