Leak on rear wheel - Defender Source
Old July 6th, 2013, 05:01 PM
sro
Sam Odio
2008 LR2
Leak on rear wheel
I have a leak on the rear right weel. The fluid is being sprayed around the inside of the tire and is building up on the bottom of the brake pad. I believe this is a hub seal leak from looking around on the forum. Brake fluid levels haven't changed.
Strangely, this happened right after I added a "homemade" (read, 3 ft of fish tank tubing) breather extension to that axle. As far as I can tell the breather line is clear, even with the extension. The extension tube is transparent so I can see that there are no obstructions there.
I can blow through the tube, though it does take some force (I'm assuming this is because of the sheer length of the tube - about 5 ft). When I connect the tub to the axle and tighten it down I can blow in the tube, but not for long b/c pressure builds up within about 1-2 seconds. I'm assuming that's because the entire axle & diff are sealed & that the fitting is not blocked. I've visually inspected the fitting and it looks fine.
To be safe I've removed my breather extension, but the hub still seems to be leaking.
Am I missing something? Is it just a coincidence that the hub is leaking right after I started working on the breather tube?
Old July 6th, 2013, 05:36 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I guess the pressure to push thru breather is superior to the pressure to go thru the old seal, so the seal is gone.
Make sure is not brake fluid before you take everything apart.
- Charles Eames
Old July 6th, 2013, 05:42 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I just replaced my leaky wheel cylinder in the rear drum on my truck after seeing the streaks on the inside of the tire. Not sure if your disk brake would have a similar issue but it could.
Old July 6th, 2013, 05:58 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Well at least gear oil has a very distinct smell vs. brake fluid.
If it's gear oil then the seal was probably already suspect and the path of least resistance once you added the longer breather.
Old July 6th, 2013, 06:19 PM
sro
Sam Odio
2008 LR2
Okay. To confirm: this is the seal I want to order right? Anything else I should change while I'm in there?
http://landroverparts.roversnorth.co...=PLH002&type=0
------ Follow up post added July 6th, 2013 03:19 PM ------
And yah it smells like gear oil.
Old July 8th, 2013, 02:07 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Check your wheel bearings for play or wear.
- Charles Eames
Old July 8th, 2013, 06:24 PM
sro
Sam Odio
2008 LR2
Okay, I'll check the bearings. And I need the hub outer seal, right? Just want to make sure I'm getting the right thing.
wheel
Help with Rear Wiper motor and jet issues minch77 Defender Technical Discussions 7 March 18th, 2015 11:48 PM
Wheel spats and rear door from 1985 110 willr For Sale - Parts 6 February 3rd, 2011 05:40 AM
110 rear bumper/spare wheel carrier/rad-blind pabrit Wanted 5 November 3rd, 2009 05:25 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
» Defender Registry
Stella
D110DC
Lang
Langley90
Add your Defender
