Leak in the radiator - Defender Source
Old March 20th, 2007, 11:03 PM
bomilcar's Avatar
bomilcar
Stephen Miller
73 Series III Orig Owner
Pinhole leak in the radiator. Before I get it re-cored any guidance? Anything new in the world of aluminum radiators? Re-core vs. new original? Any thoughts would be helpful.
Steve
73 Series III (Original Owner)
94 D-90
2011 LR4
"anything that can go wrong has"
Old March 21st, 2007, 04:46 PM
Re-core or price a new one from George at Rovers Down South. I wouldn't screw around trying to make a generic aluminum one fit.
Old March 21st, 2007, 06:24 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Is it repairable. Pin holes often are depending on the location. It may save you some serious cash. Just pull it, take it to a radiator shop, and see what they think. The last radiator I had repaired, out of a CJ, cost me $20 since I took it in. Took them less than two hours.
Food for thought.
Some people are like a slinky... not really good for anything, but you still can't help but smile
when you shove them down
the stairs.
Old March 22nd, 2007, 07:10 AM
bomilcar's Avatar
bomilcar
Stephen Miller
Thank You
Good advice guys, thanks. The aluminum custom one comes in over $900.00. Not too much to think about there, WOW. Thanks again.
Steve
94 D-90
2011 LR4
Old March 22nd, 2007, 11:53 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Let us now how it works out.
the stairs.
Old March 22nd, 2007, 10:23 PM
bomilcar's Avatar
bomilcar
Stephen Miller
Too rich for my blood. I will go with the "fix up paint up" version. The darn thing only has three rows. Seems to be origional equipment. Looks like there is room for a forth row but the radiator guys say it can not be put in. Any of you upgraded the condensor fan? Years ago I put a pusher Kenlowe in fromt of the radiator in my series III and it seemed to help some at lower RPMs. Traffic is the problem here in Houston. I will lwt you know how it all works out. Thanks for the help.
Steve
Steve
94 D-90
2011 LR4
Old March 23rd, 2007, 06:22 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
The radiator guy couldn't fix a pin hole? Is it just in a bad spot for him?
the stairs.
Old March 24th, 2007, 08:11 AM
bomilcar's Avatar
bomilcar
Stephen Miller
He could fix it. The pin hole got fixed, the radiator got disassembled, reamed out blown clean and painted. Pretty good for $60. Beats the $800+ for the fancy one. Still thinking about a Kenlowe for a pusher replacement.
Take Care,
Steve
94 D-90
2011 LR4
Old March 27th, 2007, 02:17 AM
Pusher fans are to suppliment your current, engine driven fan.
Puller fans are the replacement fans.
Lots of good, U.S. made, less expensive fans out there. A Kenlowe is big bucks compaired to a Flex-Fan from Summit Racing. Do a search at the top of the page. There are quite a few threads on "electric fans." Good luck with the Series III.
Old March 27th, 2007, 06:58 AM
bomilcar's Avatar
bomilcar
Stephen Miller
Yes Sir. My intent is to replace the small pusher fan on the front of the AC condenser with a larger unit. It does not look like that there is too much extra room to work with but I am going to cut a few templates and see. It may not be worth the trouble for the small amount of additional aire flow but I will see just what fits. You sure are correct on the Kenlowe cost not to mention shipping to the US but I have been very happy with the 20 year old one I have on the Series III. Do not know just when i will get around to doing the test fit: summer is fast approaching so it had better be soon.
Steve
94 D-90
2011 LR4
radiator
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
ATF Leak underneath Radiator shawnpalmer Defender Technical Discussions 4 January 16th, 2007 10:25 PM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
Radiator Decal Question 48vphantom Defender Technical Discussions 3 January 31st, 2005 09:42 AM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
