Leak from water pump bolt - Defender Source
Old July 6th, 2014, 05:17 PM
Streaky's Avatar
Streaky
Alden
1994/D90 NAS
I just installed a new water pump (long story). When taking off the long bolts (6 inch) that go through to the block I had trouble getting one in particular out. (The one next to the tensioner for the fan.) I had even more trouble reinstalling, but I cleaned the treads up and it felt tight during installation.
Got everything back together, started it up, and after 10 minutes running it started leaking out of that hole. (Around the bolt).
Anyone have an easy solution?
I know I could take it all apart again, helicoil it and buy a new water pump bolt. However, this engine has 250k, been rebuilt 3x and im milking it along for now. For now, I'm ok with cheap and easy.
Do you think adding some JB weld in there would do it? More rvt gasket material in the bolt hole?
...looking for options. Thanks.
Old July 6th, 2014, 05:20 PM
Streaky's Avatar
Streaky
Alden
1994/D90 NAS
A picture... if it helps.
Old July 6th, 2014, 09:55 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Water should not reach the bolt. Check following:
Both contact surface should be completely clean and scratch free
Use a quality gasket
I spray some lithium grease on the gasket (lightly) before assembling, but that's me
Torque you bolts gradually, do it in 3 steps, just in case.
If it's still leaking, check for cracks.
Cheers
- Charles Eames
Old July 6th, 2014, 11:53 PM
Streaky's Avatar
Streaky
Alden
1994/D90 NAS
Thank you. That makes sense. I assumed the longer bolts were in contact the water/antifreeze.
Old July 7th, 2014, 08:57 AM
get another bolt ... cut it vertically through the thread with a hacksaw ... use that to clean out the hole properly ... otherwise you are just compressing crap into the hole
Old July 7th, 2014, 09:01 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
^this^...or spray the crap out of it with brake cleaner and use a qtip...turning it counter clock wise. You wouldn't believe the crap in there.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old July 7th, 2014, 09:03 AM
You have 6" plus q-tips?
Old July 7th, 2014, 09:08 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
duh...doesn't everyone?
http://www.walmart.com/ip/Medline-6-...count/21854466
Rent my
Old July 7th, 2014, 09:09 AM
he must be an obstetrician
Old July 7th, 2014, 09:21 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I do it but with a rotary tool (dremel or similar) it's way easier. I pack 2 or 3 cutting discs to have a decent cut width and make 3 of them on an old bolt, works like a charm. That + brake cleaner will leave hole pristine.
Cheers
- Charles Eames
Water Leak bulkhead to windscreen frame seal JackDEF90 Defender Technical Discussions 24 September 27th, 2012 06:09 PM
Door Top Stud Water Leak? timtimtj Defender Technical Discussions 5 May 22nd, 2011 08:08 PM
Water pump bolt JBurt Defender Technical Discussions 10 February 15th, 2007 08:52 AM
AC water leak 89classic Defender Technical Discussions 2 June 12th, 2005 01:21 AM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
