Leak at Fuel Level Sending Unit?? - Defender Source
Old December 5th, 2015, 04:06 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
NAS D110 - new tank and new sending unit with new gasket and locking ring. This is the type of sending unit where its on the side of the tank on the driver-side. Installed all together in the summer during rebuild. Filled up today for the first time and gas is gushing out the sending unit area - not like a small leak - like a big leak.
I re-read parts manual and install order appears to be tank - sealing ring (rubber gasket) - sending unit - locking ring.
I tried tightening the locking ring and its bending the tabs and not moving. I don't remember the install so is this one of those locking rings that turns 90 or 180 degrees and then seats/locks? Or is it threaded all the way and you need to tighten as much as possible to get it all to seal? I have the old sending unit but not the old lock ring so cannot check that - asking here before I drain some more gas remove it all.
TIA...
AndrewT
'93 NAS D110 #437
Old December 7th, 2015, 08:22 AM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
Never mind.
'93 NAS D110 #437
Old December 7th, 2015, 08:40 AM
The rubber gasket binds as the ring twists in and bunches up. Use vaseline on the rubber gasket to keep that from happening
fuel
Need a 110 Fuel sending unit for early truck Uncle Douglas Wanted 19 September 18th, 2012 12:40 PM
WTS: 110 fuel sending unit, Terrafirma spring retainers, Land Rover Gear Sandals mcoleman762 For Sale - Parts 4 October 6th, 2011 09:13 PM
Temp sending unit 3.9L vs 300TDI - different range? jaherring Defender Technical Discussions 8 October 4th, 2010 08:22 PM
Oil Pressure Sending Unit 61rover For Sale - Parts 1 September 24th, 2009 10:24 AM
Need Oil light sending unit, 97 90 or Disco Tom Fitzgerald Wanted 2 April 14th, 2007 10:57 AM
