leak at front engine mail seal (due to vibration?) => two questions? - Page 2 - Defender Source
Old August 31st, 2006, 08:28 AM
The gasket really is easy. just label everything that you have to take apart and unplug. I did it in 7 hours taking time and thinking a lot, lookin for a lost bolt and lunch. The only bitch was the fuel injectors I didnt want to take the fuel rail off so I unpluged all the injectors and tried to fish them under the fuel rail that was a PITA. good luck.
Old August 31st, 2006, 09:12 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hum.... I did not realize that I had to take the injection system out as well.... Did you replace the O-rings of the injectors then? [Crap... I did not order those] What parts/component did you replace? So far I was told that only the gasket needed to be replaced (and two plastic "ends" that I have yet to see/find on mine)
Time to go back to the diagrams.... I am sure I missed something.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 31st, 2006, 09:19 AM
I just replace the valley pan gasket and the two rubber gaskets on the front and the back of the valley. You will find those ends once you take everything apart. and while you have the plenum off and everything out of the way you might as well replace the valve cover gaskets as well. That also reminds me I lost one of those rubber o rings from the injector, it was actually more of a square. i didnt take out the injectors just unplugged the wiring harness or whatever it is and left the actual injectors in.
Old August 31st, 2006, 09:30 AM
MonLand
Loic Fabro
Great! I do have a replacement for the rocker cover gasket. So it looks like I'll be fine! :-) Another 10 days (or so) and I'll let y'all know how it went.
MonLand
1995 D90 NAS
1996 Discovery NAS
engine
series front hub seal airbornrover Series Technical Discussions 1 November 12th, 2008 08:48 AM
Front Main Seal TND90 Defender Technical Discussions 8 March 16th, 2007 12:03 AM
300 Tdi fule leak Questions!! Buckon37s Defender Technical Discussions 13 February 28th, 2005 02:32 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
