Late td5 dash wiring - Defender Source
Old July 22nd, 2008, 10:40 AM
cabell's Avatar
cabell
Cabell Crowther
I'm going to install an '02+ MY dash in the 110. I'm trying to determine the best way to integrate the new center dash switches into the original wiring scheme. For anyone who has done this, did you install a td5 bulkhead loom or splice in connectors for the new style switches/relays? Any advice is much appreciated.
Old July 22nd, 2008, 11:22 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its next to impossible to do the Td5 loom as the wiring for the rear wiper and such is very different. We use the factory wiring and make the needed changes to suit the new style dash. Here is an example in a D90.
http://www.eastcoastrover.com/159.html
Email:
Old July 22nd, 2008, 11:58 AM
cabell's Avatar
cabell
Cabell Crowther
Thanks Fidel. My configuration is a pickup so there is no rear wiper, but I know the Td5 loom has a lot of stuff I won't need. I guess what I really am trying to find is a source for the connectors to fit the back of the switches.
Old July 22nd, 2008, 02:21 PM
cabell's Avatar
cabell
Cabell Crowther
OK, I've done a bit more homework and I think what I need are Tyco amp multilocks connectors
P/N 347477-1 and 347477-4 and whatever fits the hazard switch. Anyone have a source?
Old July 23rd, 2008, 04:33 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
The Hazzard switch is the problem. The other plugs I got from EE. I am looking into getting the Hazzard plug and will let you know. THen The questsion will be how to wire it.... I'm sure it can be done but I am not sure how to yet...
Legend in My Own Mind.
Old July 23rd, 2008, 05:05 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
If you need the Tyco connectors, you might be able to order them through a place like Allied Electronics or Newark. Neither one shows those PN's as stock, but I buy a lot of other Tyco connectors from them so they may be able to special order what you need.
www.alliedelec.com
www.newark.com
Old July 23rd, 2008, 05:13 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
The company that makes the Hazzard plug is Sumitomo Wiring Systems.. Part # F(6090-1220). Anyone I spoke with, you need to by a bag of about 10000 of them. LEt me know if you can find them in smaller numbers.
Old July 23rd, 2008, 09:19 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Are you cutting the pertinent parts of the TD5 loom out and rewiring?? How did you do it in the project you listed?
Thanks for any advice.
Old July 23rd, 2008, 09:38 PM
surf110's Avatar
surf110
Ze
130 Project
Some good info here:
http://www.reedx.net/landrover/mods/2002dash/index.htm
Old July 23rd, 2008, 10:42 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Originally Posted by surf110
Very nice info!
legend in my own mind
Old July 24th, 2008, 08:10 AM
ECR's Avatar
ECR
We just use the connectors, not a cut up Td5 harness.
The Td5 harness runs things differently so not all the switch wiring crosses over. For example the rear wiper on a NAS 110/90 won't park if you use the Td5 wiring as shown in that web page, so you have to add a relay.
What that pages shows you is how a Td5 set up works and what the factory wiring is. That helps with the hazard switch and such, but when you do an NAS it isn't a direct cross. There are minor differences.
Before you ask... no I don't have connectors to sell. I only have a handful and they are for customer cars, unless I find more somewhere.
You could find the connectors and do it like we do, or you could cut the connectors off an existing harness, or cut the sub harness out of the center console out of a Disco 2, it has most of the connectors you need.
If you want to do this without killing yourself get a junk yard to cut the connectors off a D2 junk, or a junk 90 in the UK, buying a Td5 harness would likely break the bank.
I have a Td5 110 in the shop today, so if you need pictures of the connectors let me know.
Email:
Old July 24th, 2008, 09:55 AM
cabell's Avatar
cabell
Cabell Crowther
Thanks all.
Randy,
My research shows the hazard switch is the same as used in late (98s for sure) NAS D1. I'm going to try to find one in a scrap yard and verify connector is the same. EE= Expedition Exchange? Didn't realize they had that sort of thing.
Old July 24th, 2008, 10:29 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Do you need the contacts or just the plastic part of the plug?
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 24th, 2008, 10:42 AM
cabell's Avatar
cabell
Cabell Crowther
Eric,
Contacts and plastic surround
Old July 24th, 2008, 11:00 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Our engineer is checking to see what we can find. I should have an answer in a day or two.
Eric
Eric Riston
Old July 24th, 2008, 11:44 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Cool. Contacts as well. Thanks Eric. Now who is going to figure out how to splice it in properly? lol
Old July 25th, 2008, 10:16 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I leave that to the ECR guys . I should have an answer on the plugs on Monday or Tuesday.
Eric
Eric Riston
Old August 7th, 2008, 07:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I found a plug with no inner pins, where would i get the pins?
Any news Eric
Old August 8th, 2008, 08:39 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Not yet we can buy them 12,000 at a clip from one of our normal guys. (YIKES) We are still waiting for a quote from one of the small quantity guys that we deal with. The engineer has been keeping me up to date exery few days.
Eric
Eric Riston
Old August 10th, 2008, 09:33 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have 2 plugs with no inner pins... where can I get the pins to solder to the wires?
dash, td5, wiring
Td5 complete dash wiring for sale RoverC For Sale - Parts 3 May 23rd, 2009 07:25 PM
Late Td5 Dash Fitting surf110 Defender Technical Discussions 11 August 8th, 2008 12:31 PM
early 110 dash wiring Abrooks Defender Technical Discussions 7 May 28th, 2008 04:34 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
