late seats in an early d90 - Defender Source
Old December 9th, 2013, 04:51 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Hello all,
Has anyone put later style Defender seats w/ the skinny mounting rails in an early d90 with the wider mounts? If so, what is involved, how bad? Research says it is not that difficult, but I've not heard from anyone who has actually done it.
I am deciding if I should recover my original seats or buy a refurbished set from one of the vendors here. The cost differential is not that bad and selling my old d90 seats really narrows the difference. Time savings is a bonus, plus while mechanical work is entertaining, interior & trim just don't do it for me.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 9th, 2013, 05:19 PM
If you mean the ones pre-Puma, they should bolt straight in. I've done that with mine. The seats simply bolt to the seat box and the underside is easily accessible.
If Puma seats, I have no experience.
Old December 9th, 2013, 05:21 PM
Originally Posted by pitchrollyaw View Post
Hello all,
w
many times. You simply choose one set of the existing holes the outer's or the inner's.
There is no difference between early and later (pre-2008) seats other than that the early seats are bolted to the seat box better. Buy a set of retrim kits and drop those and your seats off with an upholstery shop. They should be able to install them in a day (there is no sewing or cutting required) and then you will have new seats.
Old December 9th, 2013, 05:26 PM
jafir's Avatar
jafir
Jafir Elkurd
Does this apply to replacing MOD seats too? Could I just bolt in something like this:
http://shop.urbanlandcruisers.com/sh...30-seats-copy/
Old December 9th, 2013, 05:52 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Hello all,
w
Retrim would make your life a lot easier then, bring it to a shop to do if you don't want to deal with the headache. the kits aren't too expensive then no fabrication at all...
Old December 9th, 2013, 07:34 PM
Abrooks's Avatar
Abrooks
Tony Brooks
And retrimming them yourself isn't that heavy a lift.
Old December 10th, 2013, 08:49 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Some of the earlier seats I have seen have four bolts per rail as compared to the NAS style that have two bolts per rail, (two rails per seat) If your seat has the hard plastic back it is different than the newer seat style and a bit harder to find the re-trim kits. They are different. You can change out the bottom part of the rail so if you found some newer seats you can change them out so you do not have to drill new holes for the newer seat.
Old December 10th, 2013, 09:04 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
My 85 had the 4 bolt pattern with plastic back
Old December 11th, 2013, 08:46 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Thanks all. I will give re-trim a go. I have some kits in techno cloth on the way from Safari HP. Understand that they may not be a perfect fit on the early seats, but this is not exactly a show truck. I my try and keep the plastic backs though.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old June 4th, 2014, 07:30 PM
jafir's Avatar
jafir
Jafir Elkurd
Which do most people choose? I'm guessing the outers, closest to the edge of the seat box.
How far from the edge of the seat box are the bolt holes for the newer style seat rails?
Also, are they bolted to captive nuts on the bottom of the seat box or do I need to get to the bottom side with a wrench?
Are the bolts usually just flat head/slotted screws, and not hex head? That's what I've got right now, no hex.
Old June 4th, 2014, 07:37 PM
IMO which I may get flamed for,the way to do these is the way the MOD had the Tithonus trucks done. A bolt up from underneath with two nuts then the seat then a third nut. This way you remove the top nuts and can quickly remove the seat, yet the studs/bolts stay put and facilitate quick replacement of the seat. The seat rails are spaced up 3/8 inch due to the double nuts below the seat rail which makes the seat box lids much easier to use as they no longer foul with the seat adjuster handle in front. As far as the four holes, I use the inner set as I'm already rubbing my shoulder on the "B" pillar so spacing inward an inch and a half helps.
Old June 4th, 2014, 07:41 PM
jafir's Avatar
jafir
Jafir Elkurd
Thanks!
If I choose the inner set on both sides, do you know if a standard size cubby still fit between the seats?
Old June 4th, 2014, 08:22 PM
Thanks!
What do you consider "standard" ? In my truck a NAS cubby was retro fit by the next owner
Old June 4th, 2014, 08:25 PM
jafir's Avatar
jafir
Jafir Elkurd
I guess I don't really know. But that sounds good to me.
So I guess the nuts aren't captive on mine, the screws just turned, once I got through all of the paint.
Old June 4th, 2014, 08:35 PM
Its usually a wide plat with two "retained" nuts. Crappy design. I have had to drill the heads off many of the screws.
90, d90, seats
Looking for D90 seats AndrewW Wanted 1 December 22nd, 2012 11:29 AM
'94 D90 Front Seats ryan_newell For Sale - Parts 7 May 13th, 2010 01:26 PM
D90 Front Seats $75 grinch79 For Sale - Parts 7 April 20th, 2010 08:08 PM
FS: Two D90 Rear Jump Seats PCRover For Sale - Parts 8 May 10th, 2008 08:16 PM
