Looks like i'm on the last few items to sort out before the truck is ready. Over the past week or so I've attempted to find the correct part numbers needed. I have found some of the numbers but want to make sure they are correct before shelling out $$. Others I have been unable to find a correct number. Hope someone here can help.
The Engine is the Defender 200TDi if for some reason the needed parts are different from a Disco 200TDi.
Ill probably have a few more items once I get the rest of the truck together later today. Thanks in advance on the help.
- Intercooler/Radiator frame bushings. These are the small bushings that attach to the small nubs on the top & bottom of Rad/IC. I believe 8 are required. I found 572312 but this seems to point towards a 300TDi.
- Both oil cooler lines.
- Heater matrix coolant hoses. I believe I need BTR445 & BTR447 for the matrix that has the 90 degree downward bends. Truck is RHD.
