Largest Tires On Stock Equipment - Defender Source
Old November 8th, 2007, 02:14 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Question Largest Tires On Stock Equipment
My 95 D90 is completely stock. I was wondering what the largest tire size I could use is. Right now I don't want to lift it or anything. So what is the largest tire I can go to without any rubbing or other side effects.
Old November 8th, 2007, 03:04 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
285 75 16 fit with no issues but wheel stops still need adjustment.
--Benjamin Franklin
Old November 8th, 2007, 03:16 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
285/75-16's will also rub the front shock towers and rear upper spring perches when the axles are twisted up. In my case enough to limit articulation somewhat. You could run a wheel with more offset (or is it less?) or a set of wheel spacers (my solution) to avoid the issue, or consider 255/85-16's. Same height, but narrower so you loose the rubbing issues...
~Scott T.
'95 D-90 ST - AA Yellow
Old November 8th, 2007, 07:12 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
265/75, don't need to adjust nothing and no rubbing (so far for me )...
- Charles Eames
Old November 8th, 2007, 10:25 PM
265 75 R16 is stock on the NAS Defender 90s.
as others have said, 255 85 R16
Old November 9th, 2007, 10:53 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I've got LTB's in 34x10.50 size on stock suspension and stock alloy's. They don't rub at all even at full articulation. They measure closer to a 255 85 I believe though.
minus the turn stop adjustment anyway
Old November 9th, 2007, 01:35 PM
Cirbo's Avatar
Cirbo
Jim C.
255's will leave you wanting some new gears... like 4.10's.
Old November 9th, 2007, 02:35 PM
94SW,4.6HSE,93LWB,83 110
amen to that Cirbo !
Old November 10th, 2007, 07:47 PM
bterpstra
Brian Terpstra
94
Here's my experience so far:
265/70 - no rubbing everything worked fine. Minor adjustment to steering stops
285/55 - minimal rubbing but steering stops needed adjustment. Turning radius was not satisfactory for me.
285/55 w/ wheel spacers (1") - very minor rubbing on the right rear eyebrow. Turning circle back to normal after adjusting the steering stops back to normal.
Already had 4.10's so the change to the 285s was welcome
Old November 10th, 2007, 09:52 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Brian - do you mean 255/85 or maybe 285/75? Or are you running some sports car tires?
Old November 10th, 2007, 10:00 PM
how are the 4:10s and 285's seems like its a "alot of gear" for a 33" tire. Id figure something like a 3:75/3:80 would be good for the 33"
What are your revs on the highway?
Old November 11th, 2007, 09:54 AM
bterpstra
Brian Terpstra
94
Yup - 255/85. A bit of temporary dyslexia - just like the dyslexic agnostic who wasn't sure there really was a Dog.
BT
Would be a bit high honestly for most people, but here in CO it seems to work a bit better going up and down the hills. It wouldbe unpleasant it if I had to drive flat highways all the time. Going up and down Loveland, Vail passes, seems to work pretty well.
Old November 12th, 2007, 09:47 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
33's are still ok with stock gears..
35's with 4.10 gears makes it feel like stock again...
Legend in My Own Mind.
Old November 12th, 2007, 10:52 AM
cellulararrest
Chris Snyder
The LTB's are incredibly sluggish on the highway. Might just be because they're so knobby though. I have plans to switch out to 4.10's.
tire, tires
4 Stock Alloys and tires aschoent For Sale - Parts 1 September 9th, 2005 09:12 PM
99.9% new tires on stock rims januconn92 For Sale - Parts 8 June 14th, 2005 12:25 AM
4 - 285/75/16's on stock D90 rims, 98% new, also spare & carrier januconn92 For Sale - Parts 7 October 13th, 2004 10:31 AM
Stock Alloys & Tires for sale roverboy For Sale - Parts 0 October 6th, 2004 10:19 PM
Stock Disco XD Alloy Wheels and Tires In Washington kpracer For Sale - Parts 1 July 23rd, 2004 08:59 AM
