Largest tire on stock wheels? - Defender Source
Old February 10th, 2013, 02:17 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
What's the largest tire I can run on a stock wheel, Deep Dish Alloy to be specific?
I'll be regearing soon and am contemplating jumping to 35's, 315/75/16 specifically. Anybody running this set up? I don't particularly feel like buying steel wheels if I don't have to.
If its possible to retain the stock alloys with that size tires, are there any problems with doing so?
Old February 10th, 2013, 03:39 PM
Dan has 315s on his boosts. Jorge has 345s on his. You'll be fine.
Old February 10th, 2013, 05:56 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Interested to see how they wear with some miles on then
Old February 10th, 2013, 06:27 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
What's that mean?
Old February 10th, 2013, 06:28 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
315s fit on 7" wide alloys. They bulge a little but if you end up lifting the truck I would correct your panhard rod or you will get some weird wear patterns in the front.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 10th, 2013, 07:37 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I have 315's on 16x7 Disco Steelies and it seems fine. I think 8" is what you are supposed to have but like ini80 said it will just bulge a bit. The LR alloys have a good sized lip on the inside so it should hold the bead well.
Old February 10th, 2013, 08:18 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Larger tire, smaller rim width, equals tire pushed up in the center. You will be effecting the contact patch which then in turn can be adjusted by air pressure to some extent.
Land Rover 110
Old February 10th, 2013, 09:26 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The truck (98 D1) already has a 3" RTE lift and all the nice expensive parts to make the lift work including the RTE adjustable panhard, so I'm all set there.
Anybody run into problems with shops not wanting to mount the larger tires to stock alloys?
Old February 10th, 2013, 09:57 PM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
I like them!
ID:	66051   Click image for larger version
Old February 10th, 2013, 11:19 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
This is what I meant may not be an issue but this is the biggest thing to consider
------ Follow up post added February 10th, 2013 10:20 PM ------
Originally Posted by Chris Vitale View Post
I like them!
Looks great!
Old February 11th, 2013, 12:37 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I like them!
Sweet! What size are those?
Old February 11th, 2013, 08:01 AM
315s...
Old February 11th, 2013, 08:15 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Those are really nice...So there's no structural concern with these mounted on those rims? What pressure do you keep those at for normal use? Off road whats the lowest you've been?
Old February 11th, 2013, 08:27 AM
Kelbo's Avatar
Kelbo
Kelly
'86 110
I like them!
That looks really sweet.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 11th, 2013, 08:28 AM
Chris Vitale
Normally: 33
Off road: 15-17 (haven't found the need to go lower)
No problems...ride is smooth.
But you should get boost wheels!
Old February 11th, 2013, 08:53 AM
Bill Larson
Bill Larson
Heck, I like my 285's and dont think I'd go bigger (then grandma wouldn't go wheeling with me). Your do look pretty good on your 90, its good to know!
Old February 11th, 2013, 09:20 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
The 315/70s do look nice. For those looking for something between the 315/70 and the 285/75, this is the look with 305/70s on OME mediums.
ID:	66070   Click image for larger version
Old February 11th, 2013, 09:22 AM
Kelbo's Avatar
Kelbo
Kelly
'86 110
Your avatar has me laughing...
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 11th, 2013, 05:11 PM
More 315 pics
http://www.thestreetpeep.com/2012/05...-defender.html
Old February 11th, 2013, 05:43 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
If you already have tires picked out, the right thing to do it look at the manufacturer's specifications for that particular tire, which will include an approved rim width range.
Staying within the approved rim width range helps assure that the tire's internal stresses are within its design parameters.
Tire sidewalls are supposed to be vertical, since they're what's holding the tire tread stable against the car's weight and protecting the wheel against impacts.
Factory alloys are 7" wide (Disco 2 and P38 Range Rover are 8") which means technically the widest tire you should be running on a factory alloy is a 285/75R16... technically. But of course that is all dependent on what the tire manufacturer says.
ID:	66087   Click image for larger version
tire, wheel, wheels
Tire size help for Boost wheels on D110 silverlight Defender Technical Discussions 19 August 22nd, 2011 03:43 PM
255/85/16 vs 285/75/16 stock wheels with spacers PMKColorado Defender Technical Discussions 15 June 21st, 2010 07:44 AM
NAS D110 Stock Tube Wheels Stmpede Defender Technical Discussions 6 April 6th, 2007 03:11 PM
Stock ST swing away tire carrier Joe P For Sale - Parts 7 July 14th, 2006 05:27 PM
Aftermarket tire carrier/ stock roof rack compatibility oldscratchggf Defender Technical Discussions 9 May 18th, 2006 02:08 PM
