Largest tire on stock wheels? - Page 3 - Defender Source
Old March 26th, 2013, 05:35 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Originally Posted by Bill Larson View Post
I'm surprised that there isnt alot of talk about the Kevlar MTR's (285/75/16). I think they are great. I've had two sets on the 90's
Did you ever measure the real height once fitted?
I'd like to know if they're 33" or a little bigger.
I love my SSRs, 285/75 which are actually 34"...an extra inch is always a good thing.
But they're damn heavy...
I like the new MTR Kevlar, would think about it next time I'll be on the market for new tires.
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 26th, 2013, 06:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Red90 View Post
That size will probably need a bit of flare trimming. No big deal. It won't be simple finding 17" rims for the 90 though.
Yup - the only 17" wheels I know of are those Walker Evans jobbers. It would be nice to have a couple of options in that rim size - it might be easier getting tires in that size in the future.
Old March 26th, 2013, 06:20 PM
CamelTM's Avatar
CamelTM
Trevor
1998 Camel Trophy Defender 110 CT25
Originally Posted by fishEH View Post
Any problems running the stock shafts/diff in the front with the 315's?
I have an ARB in the rear with Rovertracks axles. Just wondering if my front will be ok with the 315's until I can upgrade the front?
Its a risk. You're loading up both the stock axle (which is a wet noodle wrapped with metalicy bits for good measure) and the 2-pin diff (well, single pin really...and its an even weaker wet noodle wrapped with metalicy bits) with the additional tire weight. Neither of those components handle the stock tyres under aggressive conditions. So a degree of caution would be wise with larger tyres.
My two bits anywhoo.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
My 315 MTR's were exactly 35"on the rim but off the vehicle. And the weight of them with Disco steelies was just under 100 lbs ( which was slightly lighter than the 285 SSRs on Wolfs that I had prior).
I know you were looking for 285 info but just in case you wanted to compare.
Old March 26th, 2013, 06:39 PM
jafir's Avatar
jafir
Jafir Elkurd
17" rims for 90:
http://lucky8llc.com/Search.aspx?CategoryID=1084
Old March 5th, 2014, 04:23 PM
rivermike's Avatar
rivermike
Michael
2008 LHD Tdci 110 Keswick Green
Just fitted a set of 900 x 16 ( 255 / 100 / 16) Michelin's on my Defender 90 .... see pics attached. Truck has 4 inch lift kit
Name:	1985 Defender 90 RHD 2.5 D Arles Blue building day 9  left side 900 x 16.jpg
ID:	90775   Click image for larger version
Name:	1985 Defender 90 RHD 2.5 D Arles Blue building day 9  left front top  900 x 16.jpg
For LHD Defender restorations and refurbishments
WEBSITE :
EMAIlL :
Current Inventory is listed in my STOCKLIST section
Worldwide shipping is our specialty
Old March 5th, 2014, 05:08 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
nice Mike! I was looking at some 9.00s the other day.
36" is getting high. But the 10" fits perfect on a 6.5 wide rim. same width as 255/85s
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 5th, 2014, 05:40 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Always good to know. Thanks.
Michele
D90 VNTdi
[O]===[O]
Old March 6th, 2014, 06:04 AM
rivermike's Avatar
rivermike
Michael
We cut up the 6.5 " Wolf rims and banded them to 8.5 ". Then blasted and powdercoated in high gloss black. The overall diameter off the MIchelin XZL profile is almost 36 ", quite a increase from the 30 " ( 235 / 85/16).
Name:	Parts Landrover Defender velgen WOLF 8.5 x 16 powdercoat black gloss.jpg
WEBSITE :
EMAIlL :
Old March 6th, 2014, 08:19 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Update: I bought HeloBubba's 315/75 KM2's and had them shipped to my work. They sent out a USPS truck to deliverthem and the only thing on the truck was my tires, haha.
I also sold my rear ARB locker and bought 2 Ashcrofts, as well as Justin's first set of Tibus HD front axles/CV's, and installed 4.12 Ashcroft gears.
The Bad: KM2's run small. These are probably closer to 34".
The Good: A larger tire would create a lot of rubbing where the cargo floor meets the wheel well, without more lift. Tread is great and they perform very well.
Some pics:
Old March 6th, 2014, 10:04 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
This setup looks f@@kin bitchin!! A true 36" tire would be too much for me but I really wish there were more skinny / tall tires available.
For shits and giggles what is the weight of those and the price tag?
------ Follow up post added March 6th, 2014 10:08 AM ------
Rivermike - you are showing off some really cool stuff!
I would love a set of Wolfs in a wider width for my 315 Goodyears. Do you have any pics/info on the process?
Old March 6th, 2014, 03:34 PM
rivermike's Avatar
rivermike
Michael
The Michelins are about 300 euro a piece ...
No pics, I have a specialist shop nearby that is cutting / welding them up.
I have attached some photos of the same rims on my 1983 Frozen Grey 110 V8 project
Name:	1983 110 White Saudie Spec V8 painted Frozen Grey day 13  255 Michelin left front low.jpg
ID:	90811   Click image for larger version
Name:	1983 110 White Saudie Spec V8 painted Frozen Grey day 13  255 Michelin left rear low.jpg
Name:	1983 110 White Saudie Spec V8 painted Frozen Grey day 13  255 Michelin rims.jpg
ID:	90813   Click image for larger version
Name:	1983 110 White Saudie Spec V8 painted Frozen Grey day 13  255 Michelin new rear suspension.jpg
WEBSITE :
EMAIlL :
tire, wheel, wheels
Tire size help for Boost wheels on D110 silverlight Defender Technical Discussions 19 August 22nd, 2011 03:43 PM
255/85/16 vs 285/75/16 stock wheels with spacers PMKColorado Defender Technical Discussions 15 June 21st, 2010 07:44 AM
NAS D110 Stock Tube Wheels Stmpede Defender Technical Discussions 6 April 6th, 2007 03:11 PM
Stock ST swing away tire carrier Joe P For Sale - Parts 7 July 14th, 2006 05:27 PM
Aftermarket tire carrier/ stock roof rack compatibility oldscratchggf Defender Technical Discussions 9 May 18th, 2006 02:08 PM
