Land rover 90 2.5na alternator replacement question - Defender Source
Old May 16th, 2016, 06:47 PM
suburbanloki's Avatar
suburbanloki
1985 Land Rover 90
So it would seem mine is shot. At least, after replacing the main ground wire and getting a nice interstate commercial battery it's going dead after two days of driving it around. (I don't think it's grounding out anywhere. I looked over it pretty carefully) Does anyone have a recommendation for a good high amerperage replacement? I put a pretty big high CCA commercial battery in there and am going to wire some accessory lights.
Thanks for the help!
________________________
That's not rust, it's "frame patina".
Old May 16th, 2016, 07:04 PM
Is your battery light on the dash coming on with the engine off and ignition on? Does the light go out when the engine is running?
Old May 16th, 2016, 09:18 PM
suburbanloki
1985 Land Rover 90
The light comes on when it starts and while it is idling. If I give it a little gas it goes off.
Old May 16th, 2016, 09:25 PM
Then your alternator is most likely working fine and you probably have a power drain when it is off.
You need someone with a meter to test things and find the problem.
If you want a bigger alternator regardless there are a bunch of recent threads discussing options that should give you the details.
Old May 16th, 2016, 09:50 PM
suburbanloki
1985 Land Rover 90
Thanks, I'll check it out.
90, ac, alternator, land rover
1986 Land Rover 90 2.5NA Diesel Clean Florida Title in Hand southernoverlandco For Sale - Vehicles 0 February 27th, 2015 04:42 PM
1984 Land Rover 90 RHD 2.5na Korongo For Sale - Vehicles 4 February 19th, 2015 08:42 AM
1987 Land Rover Ex MOD 2.5NA Landy110 For Sale - Vehicles 7 June 17th, 2014 01:40 PM
Alternator Replacement Options for Disco 200tdi isleofbones Defender Technical Discussions 7 February 23rd, 2013 03:27 PM
Old Red (B777 ONR) :: 1985 Land Rover LR90 2.5Na Homemarket model Not ROW roverman2010 Defender & Series Truck Registry 0 February 20th, 2012 11:55 AM
