Lamp screws - Defender Source
Old November 5th, 2012, 12:16 AM
sro
Sam Odio
2008 LR2
Lamp screws
The lamps on my defender are in pretty bad shape. Specifically: the screws. Most are rusted and different sizes / styles. Also, the holes (in the aluminium body) are sized differently as well.
I'd like to re-do all this right. Possibly with some aluminum rivet nuts and galvanized screws. Has anyone done this before? I'd like to know if there's an easier way before embarking down this path... I don't own a rivet gun.
Old November 5th, 2012, 06:54 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I replaced all of mine with SS, I think they were #6 or something. I couldn't find any metric sizes local. You may have to put in a metal plate, like in speakers, if the holes are too large. That is assuming you have the old style lights. If you have the newer lights with the plinths then you could just bolt the plinths in and use the ss for the screws for the lens.
Land Rover 110
Old November 5th, 2012, 09:42 AM
sro
Sam Odio
2008 LR2
I bought some stainless steel screws but haven't used them. I'm a bit worried that they'll cause corrosion of the aluminum body.
Old November 5th, 2012, 11:08 AM
DSB's Avatar
DSB
David
'84 RHD Land Rover 90 Diesel 2.5
Read this. It will help.
http://www.engineersedge.com/galvanic_capatability.htm
Old November 5th, 2012, 12:13 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
If I'm reading that table correctly, there shouldn't be any galvanic corrosion between regular steel and aluminum but there will be with stainless?? That means all those stainless kits out there are causing more damage?
Old November 5th, 2012, 01:48 PM
maleger
Marc-Andre Leger
From what I understood, between alu and stainless, the stainless will win and it<s the alu that is going to oxydize. I choose to stay with steel screws and replace them when needed rather that dammage the aluminium.
Old November 5th, 2012, 02:15 PM
sro
Sam Odio
2008 LR2
I think the kits are fine since they're bolts that attach to the steel hinges (not the aluminum body).
I don't think it's a good idea to use stainless for the lamp screws.
Old November 5th, 2012, 03:46 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Can someone please explain that chart?
1) Is it listing 2 dissimilar metals and its Anodic index? I cannot find where it compares aluminum to SS.
2) Is it saying the Anodic index of hot-dip-zinc-plate vs galvanized steel is 1.20?
I am sure I am misreading this, otherwise why would anyone use galvanized steel?
MUDSUX
Old November 5th, 2012, 04:22 PM
DSB's Avatar
DSB
David
Here is a better chart.
http://www.marfas.com/corrosion.shtml
------ Follow up post added November 5th, 2012 05:26 PM ------
The previous chart gives the index. Take the two numbers and subtract the difference. If the number is equal to or less than the environment listed you should be ok. Zinc dip and galv are on the same line. Their index is 1.20.
I hope this helps.
The latter of the two links is better.
Cheers
Old November 5th, 2012, 04:33 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I hope this helps.
Cheers
Thanks for that. So take the two numbers and subtract the difference; but there are 3 numbers listed for aluminum. Sorry I am just very confused with that chart. It's like a chemist trying to explain something to a highschool dropout Can you help me with this?
What is the index for using SS bolts on galvanized steel?
What is the index for using SS bolts on aluminum?
Anyway, I wonder why there is such a push in the Land Rover community to go stainless?
MUDSUX
lamp
NAS light screws - lamp to plinth cabell Wanted 3 January 24th, 2011 04:30 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
Equipe lamp protectors wanted RoverC Wanted 8 March 14th, 2006 08:45 PM
Orange Check Engine Lamp Scoop Defender Technical Discussions 9 March 12th, 2006 07:51 AM
Rear (Red) fog lamp? dmarchand Misc. Chit-Chat 24 August 4th, 2004 10:53 AM
