Knocking when low RPMs but Accelerator depressed near floor - Defender Source
Old July 31st, 2011, 09:40 PM
So, I have a new sound. Say, I should be in 3rd gear, but I'm really in 4th and at a low-ish speed. In this example, when I depress the accelerator near the floor in 4th to get up to speed, I'm getting a knocking sound. Fuel level is at 3/4 (I just put in $40) and SHOULD be premium...could this sound just be attributed to low octane fuel? Oil level is just fine, too. Twice today, when pulling out onto a street in 1st gear from a complete stop, I got a knocking sound that sounded just like the sound you'd hear before the fuel fully cuts out on an empty tank.
Old August 1st, 2011, 09:35 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Sounds like pre-detonation which can be due to various reasons but usually due to ignition timing (including advance) or fuel quality.
Old August 1st, 2011, 02:07 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Does your oil light flicker at all when at idle?
Old August 1st, 2011, 02:33 PM
mine seems to have started doing this exact same thing when I lug the engine in too high of a gear. I dont exactly know when it started doing this. I honestly dont pay it any mind, Ive never ran out of fuel so I cant comment.
Old August 1st, 2011, 02:40 PM
Isn't this simply that you are in too low of a gear and the engine doesn't have the power/torque to handle the load? I think the answer is just to downshift
Originally Posted by pendy
I'm here for the D's
Old August 1st, 2011, 03:23 PM
No oil flicker. That was the first thing I figured was low pressure. I had put all new oil in about two weeks ago and topped her off.
Charles that's the obvious solution. It's a rather new sound to the truck though. Only really happens in 4th, and aside from that it doesn't really worry me except for the no fuel sound when starting off in 1st.
Old August 1st, 2011, 03:32 PM
Naplm00
Matthew
Welcome to the club...ugh
ac
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 12:02 PM
misfires at low rpms sometimes jdb3760 Defender Technical Discussions 1 December 3rd, 2006 09:50 AM
Low RPM knocking, ideas? OCD90 Defender Technical Discussions 6 September 30th, 2005 05:14 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
