Knocking sound at idle - Defender Source
Old March 11th, 2012, 10:04 PM
slatelacy
Slate Lacy
94 ST
I recently bought a 94 d90 with 109xxx miles. When I bought it, it had about 250 miles on a brand new Bosch 4.6 installed by the guys at West Coast Rovers. After about 300 miles (and two broken belts) I finally figured out that they never installed the spacer on the crankshaft, causing the whole pulley assembly to move forward. Luckily, Will Tillery fixed that problem, by installing a spacer. The truck seems to run fine at normal Rpms, but at warm idle, which reads at around 800rpms, there is a good deal of vibration and a knocking sound. Any ideas????
Old March 12th, 2012, 01:49 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Ehaust leak? I had a knocking/ticking sound to one side and found a bolt had backed out. I installed a new bolt and the ticking has all gone away. Easiest fixed I could have imagined.
Old March 12th, 2012, 02:00 PM
slatelacy
Slate Lacy
94 ST
That was a thought, but it sure sounds like its inside the engine itself. Plus, I don't hear it during normal driving. I guess it still could be. I would have hoped after a new engine install, that wouldn't be an issue.
Old March 12th, 2012, 02:02 PM
It could also be valve tap as well. an experienced person could tell the difference in sound between valve and exhaust leak. if it's valve, you might have a bad hydraulic lifter or valve spring.
Old March 12th, 2012, 02:04 PM
1of40's Avatar
1of40
1of40
that sux, good luck. you want it to be a simple exhaust leak and not something sexier. mine didnt knock at driving speeds either, nor did it overheat. run the engine cold in the pitch dark and look for flashing light maybe too.
Old March 12th, 2012, 03:43 PM
slatelacy
Slate Lacy
94 ST
I'll give it a try. I sure wouldn't think that a brand new engine would have valve problems, but given the fact that they left the spacer off of the crankshaft, anything is possible. Would a valve issue explain the rough vibration at idle?
Old March 12th, 2012, 03:44 PM
Why didnt you take it back to the people that "built" the engine?
Old March 12th, 2012, 03:56 PM
slatelacy
Slate Lacy
94 ST
I would love too, but they are in Ca and I am in Nc. Long drive.
Old March 12th, 2012, 04:30 PM
Naplm00
Matthew
try posting a video with sound on youtube so whe know what your talking about
Old March 12th, 2012, 05:51 PM
slatelacy
Slate Lacy
94 ST
I hope this works.
<iframe width="480" height="360" src="http://www.youtube.com/embed/hnmqoFuARMM?rel=0" frameborder="0" allowfullscreen></iframe>
Old March 12th, 2012, 05:57 PM
Try this instead.
http://www.youtube.com/v/hnmqoFuARMM
Old March 12th, 2012, 06:03 PM
slatelacy
Slate Lacy
94 ST
Thanks you sir. Computers scare me.
Old March 12th, 2012, 06:04 PM
There's new and then there's new. Is it new like came from the factory never installed or even run ever before? Or is it new like we took it apart, put all new gaskets and bearings and rings and put it back together new?
Thing is, that if it's the latter, there is a possibility that you are hearing a wrist pin or some other thing that was not discovered in the course of the engine rebuild. If that's the case then I'd have the people who sold you the engine bear the response.
Old March 12th, 2012, 06:18 PM
slatelacy
Slate Lacy
94 ST
Brand new, never installed 4.6L short block, GEMS types 1996-1998. $4750 according to the receipt that I have from West Coast British.
Old March 12th, 2012, 06:47 PM
Naplm00
Matthew
youch,
does the knocking instantly go away just slightly above idle? Is the truck a manual or auto? aLso have you checked the oil level and quality? any metal or sparkles in the oil?
Old March 12th, 2012, 07:05 PM
slatelacy
Slate Lacy
94 ST
It does go away just above idle. It is a manual R380. Just did the initial 1k oil change with Mobil 1 15w-50. I had it done at a shop, so I didn't see the oil. I got the truck with about 300 miles on the new motor and broke it in by the book. Never exceeded 3000rpms and varied engine load for the first 1000 miles.
Old March 12th, 2012, 07:32 PM
I'd be on the phone with those guys first thing tomorrow.
Old March 12th, 2012, 08:18 PM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
No expert but sounds like computer not set up for engine. Serious spark and timing issues.
Why does intake plenum still say 3.9? Js
Old March 12th, 2012, 08:30 PM
slatelacy
Slate Lacy
94 ST
I thought that as well. At least that would be an easy fix. I was told that the 3.9 cover was left on the engine to deal with Cali laws for some reason.
Old March 13th, 2012, 04:21 PM
aka rover's Avatar
aka rover
ed angel
95 D90
The sound of the exhaust is a miss fire for sure, as far as the 3.9 intake ? what would you like it to say? your other option is to say 4.2.
Mine still has the 3.9 intake not a problem at all but you do need proper chip to run the 4.6, some use the 4.2 chip Mine is a RPI chip if I remember correctly.
Hard to tell from video the knock sound but you may have better luck from under the truck near the oil pan. you can also take a long screw driver and place the tip on the valve covers etc. and your ear on the other end and listen to see if you can tell if its internal and which side etc.
85 D110 3.5 3 DR
idle
Help...When I press on the brakes, I hear a knocking sound WEMICHENER Defender Technical Discussions 4 February 17th, 2007 04:24 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
