Knocking sound at idle - Page 2 - Defender Source
Old March 13th, 2012, 04:51 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
I thought I had a tapping valve and turned out to be a noisy AC pulley bearing................
Todd
'95 D90 #2206
'66 109" P/U
Old March 13th, 2012, 07:04 PM
slatelacy
Slate Lacy
94 ST
I emailed west coast rover. They suggested the sound to be a lifter and suggesting adding Lucas oil additive. They also told me that the truck is running stock ecu, as the previous owner did not want to buy the chip from RPI. I will be ordering the chip ASAP. How the hell could the motor run correctly if the computer thinks its still a 3.9???
Old March 13th, 2012, 07:13 PM
willtillery
WILL TILLERY
TO MANY ROVERS
While you may not tap into the increased power of your 4.6 you could drive the truck to Cali and back on a stock 3.9 ecu and still not get a knock at idle.
Bring it on up before you throw any parts at it. I will take a look at it.
Old March 13th, 2012, 07:23 PM
willtillery
WILL TILLERY
TO MANY ROVERS
Find out what cam they used......
Old March 13th, 2012, 07:39 PM
slatelacy
Slate Lacy
94 ST
Isky cam 262d.
Old March 13th, 2012, 08:07 PM
This is bull-oney. If it is a lifter, it could be collapsed which will give you all kinds of bother. I had knock at idle on a recent rebuild and when I opened up the valley I could plainly see the #8 exhaust lifter had come apart spurting the piston out the top of the lifter with the pushrod off to the side and doing very little other than being noisy. This wasn't particularly harmful nor did it do any damage. It did make the truck flunk smog. I would urge you to not drive it very much until you have this definitively sorted out.
Oil additive? Really?
Old March 14th, 2012, 06:37 AM
willtillery
WILL TILLERY
TO MANY ROVERS
Yep..Bring it on up.. I will take a look at it.. The reason I asked about the cam is because on some of the rigs people complained about a tap/knock... It was the cam walking at idle and start up....It was tapping on the inside of the front cover.
I dont suggest snake oil on a brand new motor... I would suggest lucas on a 300k motor that someone is trying to slow down an oil leak and doesnt want to spend the funds repairing it.
Old March 14th, 2012, 08:36 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Cat rattle.
Matt Browne
Old March 14th, 2012, 09:26 PM
I'm guessing pulley bearing.
Old March 14th, 2012, 09:30 PM
Flux inverter.
idle
Help...When I press on the brakes, I hear a knocking sound WEMICHENER Defender Technical Discussions 4 February 17th, 2007 04:24 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
