KM2 Blow out - Page 2 - Defender Source
Old May 16th, 2011, 09:53 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
An outward bubble on the sidewall can either be cord overlap or a impact damage that has separated the sidewall cording allowing air to push it out. Shortcording will cause a depression in the sidewall. The shortcording and cord overlap are not a defect in the tire. But the bubble in the sidewall caused from impact damage isn't good.
Doug, I am glad you fared well from the tire blow. The problem is, however, by the time you were able to get the truck stopped the damage to the tire was done in such a fashion that it is hard to tell what caused it. Sucks what ever the reason.
The KM2 you have has a "Q" speed rating, 99 MPH.
Land Rover 110
Old May 17th, 2011, 08:36 AM
haven't gone there.....according to Garmin my top speed to date in the 130 is 83mph. Picture down a mountain grade with a 110 on the car trailer-pretty much the way I pulled up to your house.
Old May 17th, 2011, 08:49 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Doug, glad you are okay!
Charles, change that damn tire! we talked about that thing two weeks ago!
Old May 17th, 2011, 01:48 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Originally Posted by Overlander View Post
I've never heard of BFG MT's blowing out. That's about the toughest sidewall I know of.
Tough sidewalls can be the cause of blowouts and not the solution to the issue. Radial tires work well because of their thin supple side walls. A when a tire flexes it generates heat. The thin sidewall of a radial tire is designed to dissipate the heat. An underinflated or overloaded tire can generate enough heat to delaminate the tire. Often you can't tell by inspection that it has an issue, but sometimes a bubble will appear.
BFG beefs up their sidewalls on the radial to prevent rock damage, but there is a compromise because of it.
Check your sidewall tire temperature sometime after extended offloading when you air down to 12 psi or so. It may surprise you how hot it gets at low speed driving, especially with BFG's.
That said, I love my BFG A/Tís never failed me YET
--Benjamin Franklin
Detroit Locker Blow out Fivespddisco The Vendors Loft 0 February 4th, 2011 11:21 PM
Did I blow up my diff?? TexasD-90 Defender Technical Discussions 29 January 5th, 2011 07:54 PM
255/85/16 km2 TexasD-90 Defender Technical Discussions 20 December 3rd, 2010 02:19 PM
Door Innards Blow up/ picture.. mightymg Defender Technical Discussions 1 October 25th, 2009 09:41 PM
$1500 to blow gtg067i Defender Technical Discussions 18 November 2nd, 2005 09:11 AM
