kill me please! - Defender Source
Old June 2nd, 2006, 07:39 AM
vesparover's Avatar
vesparover
brian bertolini
Exclamation kill me please!
I'm ready to cry. Here's the rundown: My 3.9 block acted like it had blown the head gasket last year (500 miles away In the mountains of west virginia). So, I change that, had the heads done put it all back together and it was still losing all the coolant out the exhaust. So, I figure I misdiagnosed it and it was a cracked block. So, I buy a 4.6 block have the heads inspected again and I finally put it back together. It immediately starts pumping coolant out the exhaust pipe- this time like a bilge pump! UNREAL- I almost lost it right then. So my concensus is that maybe the machine shop didn't see a crack in the heads and it's dumping into the combustion chamber? Now I had that machine shop mill the heads, do the valves, supposidly pressure test them and all that. What's the concensus?
Brian Bertolini
Old June 2nd, 2006, 11:44 AM
Maybe take a look here.
http://www.defendersource.com/forum/...ead.php?t=7705
Might not be the exact problem but there is allot of good info there.
Surrey top for sale Cirbo For Sale - Parts 11 August 27th, 2009 08:29 PM
110 Kill Switch Removal bjf Defender Technical Discussions 4 July 4th, 2009 04:17 PM
Battery kill switch and ECU Grover Defender Technical Discussions 17 January 2nd, 2009 11:34 AM
Time to kill of the carpet and seats... KMarshall Defender Technical Discussions 11 April 26th, 2006 03:13 PM
Fuel Delivery Problem JOE BAGGS Defender Technical Discussions 2 January 7th, 2005 09:44 PM
