Kickpanel insulation - Defender Source
Old April 12th, 2012, 06:28 PM
aosias's Avatar
aosias
Alexandra
1995 D90
So- in my quest to turn my old ass Defender into a Range Rover not-supercharged. I have the insulated kick panel "things" to install. Did the driver's side all by myself. I have the correct AC friendly part for the passenger side.
I know the correct way to install this would be to remove the AC, install the trim piece and then re-install the AC.
BUT I don't want to do that. So- any ideas on how I can shove this up behind the AC in the passenger side?
Or do I just cut it down and then shove it back there.
I'm also a realist and know that this is probably just a placebo effect- but I have these parts and couldn't sell them so here I am.
Old April 12th, 2012, 09:09 PM
The aluminum ones? you could just bend it, shove in, and bend back no?
Originally Posted by pendy
I'm here for the D's
Old April 12th, 2012, 09:53 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Rubber ones like this only LHD
http://www.safarihp.com/defender/def...ll-rubber.html
Old April 12th, 2012, 09:59 PM
Basically have to pull the AC. Otherwise you ought to just toss it in the bin as it won't look or work right if you try to hack it. Not even Ron good on this one.
Old April 12th, 2012, 10:02 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Ouch! So not what I wanted to hear.
Old April 13th, 2012, 05:32 AM
Oh, that part that's one piece for each side? If it was the big one piece, I'd agree with Ron, but I have to admit I cheated when installing one of those in my Tdi 90. I loosened the AC and worked it in and out of position a few times, cutting just what I needed to get it into position. You looses little of the insulation/sound deadening properties, but it actually better than Ron good per me,
Old April 13th, 2012, 09:00 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Loosen, cut and wiggle I will. Sounds like something right up my toddler's alley. Thinking some tape on the cuts and I should be good to go. There are two holes with tubes/wires and one of those is the drain.
Oh the silence this will provide
Old April 13th, 2012, 11:18 AM
discotdi
Todd Miller
Land Rover
Let us know how it works out, insulation wise.
Old April 13th, 2012, 11:34 AM
aosias's Avatar
aosias
Alexandra
1995 D90
What? I didn't hear what you said.
LT 77 Insulation Mat aosias For Sale - Parts 6 March 15th, 2012 06:28 PM
LHD and RHD Firewall Rubber Insulation Kits NTO SafariHP The Vendors Loft 1 December 24th, 2010 12:47 PM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
Any issues with putting sound insulation underneath rubber mats? arbik Defender Technical Discussions 3 February 25th, 2005 02:27 PM
Replace tranny hump insulation??? JRowe Defender Technical Discussions 8 October 16th, 2003 10:35 PM
