key stuck in ignition - Defender Source
Old September 25th, 2006, 03:53 PM
D901619's Avatar
D901619
oscar
I cant get my key out off the ignition switch, it loks and un locks the steering wheel and starts the car every thing works . i just cant remove it. please help thanks
Old September 25th, 2006, 03:57 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Sounds like you need a new ignition switch cylinder. If you can't forcefully remove the key, you might have to get a new ignition switch cylinder. (They come with a new new ignition key) Try removing the plastic shroud, spray some WD40 in the hole and give it a few taps. If that don't work go to plan A
Neil
Old September 25th, 2006, 04:02 PM
beck427
G.D.Beckmann
97 D90 LE
your key has a slight twist and the ignition doesn't like it, prob from unlocking doors. Disconnect the battery and turn the key as to start it and push just a bit more than usual....you'll feel it. then it should just come out. It may be time for a new key or just put it in a doorlock and straighten it every now and then...works for me.
Old September 25th, 2006, 04:06 PM
uh.. the ignition key doesnt lock or unlock anything on a Defender
Old September 25th, 2006, 04:12 PM
beck427
G.D.Beckmann
97 D90 LE
well mine must be special b/c it is the only key I have and it starts locks and unlocks it all
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
This may sound simplistic, but try turning your steering wheel back and forth as you pull on the key.
Old September 25th, 2006, 04:17 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Defenders lock!?!
"It's not a Jeep"
Old September 25th, 2006, 04:20 PM
D901619's Avatar
D901619
oscar
it's been stuck there so long i cant remember if it loked or not. the point is i can get the key out. i will try what you guys sugest so far. thanks for the quick replys.
Old September 25th, 2006, 05:05 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
Before getting too drastic, definitely try Rod's advice. My key feels stuck frequently, and all it takes to free is rotating the steering wheel a tiny bit counter-clockwise. You could also try jiggling the gearshift, if yours is an automatic.
Old September 25th, 2006, 05:48 PM
Chaucer
Will
93 110 | 97 90
I have used my ignition key for the door lock a few times. You have to use the "jiggle" method to get it to turn (insert key, jiggle vigorously while trying to turn/unlock). It works like a charm, every time.
Old September 25th, 2006, 06:56 PM
artm
Arthur Maravelis
97 SW
My 90 door key works on the 110!
Old September 25th, 2006, 07:07 PM
Trevor Tarr
Trevor Tarr
Back in high school, I discoverd the side door key to my parents' house would start a friend's '63 Jaguar XKE roadster (btw, one of my favorite cars of all time).
Old September 25th, 2006, 07:33 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Trevor--it is on my classic list as well. A cool site you might like: http://www.mckennasgarage.com/xke/index.htm
Sorry for the hijack, folks.
Ont he plus side, Oscar, replacing the key/ignition is simple to do. My truck's ignition key is totally different from the door keys, however.
Old September 25th, 2006, 07:36 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Oscar-
I have a 97 w/ automatic trans and sometimes I have to push the shifter a little further than the Park marked on the shifter sheet to get the key to release. If you have a manual I have no idea. Where about are you in Corona? I'm in Riverside just down the road.
Old September 26th, 2006, 02:18 AM
D901619's Avatar
D901619
oscar
south Corona by Tom's Farms 15 frwy south Weirick exit
Old September 26th, 2006, 09:50 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
When did you two guys show up?! I'm in Temecula. Work a lot in Corona. Are you guys wheelers?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 26th, 2006, 09:59 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
One other thing to check if its an 97 auto D90, (while in Park) take a small knife or flat head screw driver and pop off the center cap on the top of the shifter. In there you will see a small switch that engages when you shift. Once in a while that wont fully return to the safe position when you put it into Park and wont allow you to remove the key. Use the knife or screw driver and just help it back up into place and your key should remove. Mine was doing that once in a while and its just not clicking fully into its safe setting. A little WD40 fixed it up for me.
Chris von C
[/size]
Old September 26th, 2006, 12:23 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Hey Chris, thanks for that tip, I think I'll give that a try as I have to really push the shifter forward to get my key out.
David, mostly a lurker on this site, but love to get out to the local mountains as time allows. My D is a little too much of a queen for the hammers so I defer to my Zuk for those rock oriented excursions! Still trying to figure out how to get my D to climb a light pole
Oscar, let me know if you want me to try and lend a hand. I'm not too good with mechanical stuff, but really know how to sympathize with Defender problems!
Old September 26th, 2006, 05:39 PM
D901619's Avatar
D901619
oscar
it worked, i got the key out. just like chrisvonc said. MUCHAS GRACIAS AMIGOS!!!!
hey buckons and 97d90 how about a run up to cleghorn 15frwy by the truck scales. my d90 is a a bit of a queen when it comes to 4x4 but at times she wil put on a g string and ruff it. for the hard stuff my son and i run a yj and a cj all done up. thanks again guys.
Old September 26th, 2006, 06:29 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Man, an off-road trip wiht other Defenders! Let me know when you are thinking and I'd defintely be up for a Cleghorn run. It would be good to go off roading and not listen to all the jealous cat calls of those J%$P guys
Help! Key Stuck in Ignition - Electrical Problem wadaman Defender Technical Discussions 15 June 19th, 2009 04:38 PM
replacing ignition key - 94 snosrfr Defender Technical Discussions 10 June 1st, 2005 01:41 AM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
