Key not working? - Defender Source
Old January 18th, 2013, 03:14 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Key not working?
Anyone ever experience this? Key has been working to crank my 90 just fine until today. Put key in, will not turn. I tried multiple times, but it acted like it wasn't correct key. I took key out and tried again and it worked...NFC
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 18th, 2013, 03:20 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Sometimes it can be the steering wheel lock and you can rock the wheel back and forth to get it to turn, and sometimes one of the tumblers can develop a burr and get hung up in the cylinder.
Semper Fi!
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Is the steering wheel locked? If so you can jiggle the wheel back and forth while you ease the key forward. Happens to mine all the time. Something to do with the locking mechanism getting loose.
B
Old January 18th, 2013, 03:24 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I turned the wheel back and forth thinking that was it, I had someone push the truck to roll it while I turned the wheel and it finally turned. Most likely the lock mechanism.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 19th, 2013, 08:54 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Squirt the inside of the ignition with a shot of WD40. Should lengthen the life a bit.
Old January 19th, 2013, 10:10 PM
No silicon spray use a dry lubricant not wet like wd40
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
can someone find me a working link to that awesome land rover bbc video? rustydefender Misc. Chit-Chat 7 June 16th, 2005 04:36 PM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
