Key help - Defender Source
Old March 16th, 2015, 10:48 PM
Kdawg97m3
Kristian
1994 D90
Key help
Guys I have a 94 d90 and I have lost my keys...gone..actually my grandfather gave them away when he sold a car..don't ask...so I need new keys. What are my options and what do I do? Please help no really knows what options I have. LRNA can't help, British Atlantic doesn't know..I am kind screwed...please help!!
Old March 16th, 2015, 10:50 PM
You could sell the truck to me cheap since it doesn't start or run or buy a new ignition switch with keys. What a PITA situation.
Old March 16th, 2015, 10:53 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
I had a friend lose his remote key entry controller for his car and we found a local locksmith that came to his house and re-keyed the whole system. Maybe that's an option here? It ran him about $300 for the new controller and the time it took. I would start there and see if they can do a key set for you.
You should buy a blank door key and a blank ignition key first to help them get started. If you open the dash, behind the instrument cluster, there should be a tag tied to your steering column. That indicates the key serial number, and that could be helpful.
Old March 16th, 2015, 10:55 PM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
Call a reputable locksmith. It is what they do for a living.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Kdawg97m3
Kristian
1994 D90
Nope can't cut a key...called about 50 locksmiths..no go..
Old March 16th, 2015, 10:59 PM
rankar's Avatar
rankar
If you open the dash, behind the instrument cluster, there should be a tag tied to your steering column. That indicates the key serial number, and that could be helpful when contacting land rover.
Old March 16th, 2015, 11:01 PM
Kdawg97m3
Kristian
1994 D90
That would be very helpful.,,,,..thank you sir..I have no issue buying a new igniton and lock cylinder but seems these are NLA? No one knows shit at my local LR DEALER..sorry just frustrated...
Old March 16th, 2015, 11:05 PM
rankar's Avatar
rankar
the instrument cluster is easy to take off, just four screws and it pulls straight out. careful when handling that tag (if it's still there, I hope it is). it was printed with crappy ink, so handle it like you've just found the only copy of the Constitution outside of the Smithsonian.
Old March 16th, 2015, 11:06 PM
Kdawg97m3
Kristian
1994 D90
Thank you for letting me know about the tag....i have pulled the cluster to fix my speedo cable should be easy.....I hope it is there too. Thank you again for your help...I really appreciate it.
Old March 16th, 2015, 11:23 PM
rankar's Avatar
rankar
Let us know what you find
Old March 17th, 2015, 09:17 PM
Greg S
Greg Sutfin
1986 90
Try a real Locksmith. The 51st. one will be the one that can do it. Maybe ask you local Locksmith if he could recommend one who does automotive because it is a specialty. Any Land Rover lock I've seen has been rather simple and not involving electronic security unless it is a Range Rover or Discovery.
Jeez man, it's what locksmiths do. I've gotta shake my head at the responses your getting.
Old March 17th, 2015, 10:09 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Well shit, learn something new every day. Glad I left that tag on when I replaced ignition switch!
Awesome!
Attributed to Shayne...
Old March 17th, 2015, 11:41 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
A good, experienced locksmith will use a process called "impression a key".
Depending on the tolerance to which the lock is built, the process can be difficult.
Our Defender locks should be fairly easy, after all they are not German made locks.
Old March 18th, 2015, 07:29 AM
A new lock set is not expensive. And that comes with keys ...
Old March 20th, 2015, 08:30 PM
Kdawg97m3
Kristian
1994 D90
All good..found tag behind cluster...had Coker cut..,back on the road!, thanks for everyone's help!
Old March 20th, 2015, 11:20 PM
rankar's Avatar
rankar
Bitchin awesome
Old March 20th, 2015, 11:53 PM
rankar's Avatar
rankar
Oh and how much did they charge?
HELP! Key won't turn past 1st position svxaddict Defender Technical Discussions 8 June 25th, 2014 02:44 PM
Help! Cant get the key to turn over hotroddef90 Defender Technical Discussions 10 October 27th, 2012 04:51 PM
Lost key help. BadMonkey Wanted 10 April 8th, 2011 09:58 AM
Lost key to locking gas cap...HELP!!! tebby Defender Technical Discussions 13 November 23rd, 2009 05:53 PM
Help! Key Stuck in Ignition - Electrical Problem wadaman Defender Technical Discussions 15 June 19th, 2009 04:38 PM
