Key! - Defender Source
Old January 19th, 2011, 03:47 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Key!
Anyone experience trouble with the ignition switch? I just found out that mine as a problem. If I touch the key, even just touch it, it stop the engine.. Any guess? Can it be mended? I rather repair then change the unit..
Old January 19th, 2011, 03:53 PM
Your Ignition Switch innards may have come apart (the glue isn't the best in really hot or cold I've seen).
Here was my thread on the switch, with pics, etc.
http://www.defendersource.com/forum/...2&postcount=22
http://www.defendersource.com/forum/...ad.php?t=26677
Old January 19th, 2011, 04:32 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Is it possible that the first part (where the key enters) has a problem and not the last part where the wires are connected? Is there different quality of material? Should I pay 100$ for a land-rover genuine part?
Old January 19th, 2011, 04:36 PM
I guess anything is possible, but the ignition switch fails more frequently than the ignition module, and the switch is like a $18 part from:
http://www.partsgeek.com/catalog/199...on_switch.html
(which is what I replaced with, and have not had any issues since)
Help! Key Stuck in Ignition - Electrical Problem wadaman Defender Technical Discussions 15 June 19th, 2009 04:38 PM
door key 1997 d-90 hamiamham Defender Technical Discussions 0 June 17th, 2008 11:22 AM
replacing ignition key - 94 snosrfr Defender Technical Discussions 10 June 1st, 2005 01:41 AM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
