Keeping the Steering Tight - Defender Source
Old August 23rd, 2012, 11:42 AM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
So I recently replaced my steering dampner on my '97 D90 SW. The original was shot.
It feels much tighter now but I still get some shuttering in the front end after hitting a big bump at highway speeds. Also, the play in the steering wheel when my 90 is at rest is equivalent to 1 hour on the clock.
What is the next thing to adjust, rebuild or replace?
Old August 23rd, 2012, 11:51 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Idler and Pitman Arm?
Old August 23rd, 2012, 12:43 PM
check your bushings...
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
How many miles??? Swivel pin tension???
Old August 23rd, 2012, 05:19 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Adjustment screw on the steering box, Pan hard bushings, steering shaft U-joints, I just found out the lower swivel/u-joint on my steering shaft is shot. Play between your steering wheel and steering box will make a huge difference in steering response. I assume you have checked your tie rod ends?
Old August 23rd, 2012, 05:32 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
I appreciate the list of things to start checking. I'll dig in on Saturday.
Oh yeah... it has about 135k on it.
Old August 23rd, 2012, 06:23 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Another vote for just tightening the adjustment screw on the box. I had about 3hrs worth of play and it tightened it right up
Old August 23rd, 2012, 08:42 PM
if its got the shimmy on the highway swivel pins are also something to think about. It is really easy to check the preload.
Old August 24th, 2012, 07:04 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The damper is the last thing to replace.
Remove the damper and get the steering good checking the things people mentioned. When it's good, then replace the damper. Steering dampers aren't meant to correct loose steering or death wobble.
Be methodical in checking things.
Make sure your hubs don't have play and your lug nuts are tight.
Have someone help you by moving the steering wheel back and forth, just to where they get resistance, while you look for relative movement between all connections in the linkage all the way to the wheels.
If that all looks good, check swivel preload and adjust if needed.
The suspension bushes also, as mentioned.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
ht
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Loose steering kellymoe Defender Technical Discussions 2 October 15th, 2004 08:42 PM
