Kat's freeze plug heater - 300tdi - Defender Source
Old April 12th, 2013, 12:02 PM
pabrit
Steve Hoare
1949 80"
Is it okay to use the front freeze plug, (behind the alternator) to install a Kat's freeze plug heater?
It appears to be readily accessible without the need to dismantle manifolds etc.
Steve H
Old April 12th, 2013, 09:50 PM
Steve H
Steve:
This is the one I was/am planning to install (Kat's 11441):
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
There's a thread around here about it, and apparently it's a perfect fit and an easy swap. However, it's fallen down the list of things "to do".
Hope all is well on your end man, and that we cross paths again soon! How's the truck running?
------ Follow up post added April 12th, 2013 09:53 PM ------
Found the thread...show's you my memory is shot, I'm the one that started the damn thing:
http://www.defendersource.com/forum/...=Kat%27s+11441
Old April 13th, 2013, 12:12 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Though difficult to reach, I put the KATz in the center plug location. I figured the heat would be better distributed from there.
Now that I have replaced the manifold gasket (unrelated to freeze plug), I'd say drop the manifolds for easier access to the center plug. Dropping the manifolds is easy to do as all the bolts/nuts are easy to access. I'd advise replacing the gasket IF you decide to go that route.
Old April 13th, 2013, 08:00 AM
pabrit
Steve Hoare
1949 80"
Thank you, Gents.
300tdi, heater, tdi
300 Tdi Freeze Plug Part # aosias Defender Technical Discussions 12 February 5th, 2013 09:05 PM
300Tdi with a leaky Freeze Plug...Errrrrr TDI Guy Defender Technical Discussions 14 July 2nd, 2009 10:02 PM
300tdi Temp Sender Plug TDI Guy Defender Technical Discussions 3 April 19th, 2009 08:02 PM
Diesel starter heater plug light seaswood Smaller Projects 4 March 6th, 2009 07:57 PM
Cutting off heater hoses on 300Tdi... JFD Defender Technical Discussions 4 September 20th, 2006 09:11 PM
