Just how many different swivel housings are there? - Defender Source
Old June 24th, 2012, 05:36 PM
Am looking at three different ones here. One set is RRC ABS. One appears to be defender due to the tall Railco bush. One seems to be non ABS RRC or Disco.
I'm trying to make one good front axle out of all the ones on hand here. Nothing seems to be mating up.
Guess I need to start from scratch
Old June 24th, 2012, 09:25 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I know of two different types, one has a conical bearing top and bottom. The other has the flat bearing on the top. The ABS style has the hole in the top pin and the non ABS does not have the hole in the top pin. The top pins are different between the two different swivels. The bottom bearing and pins are the same between the two types of swivels. The swivel housings should be the same.
Land Rover 110
Swivel Fluid rover4x4 Defender Technical Discussions 3 October 12th, 2005 03:07 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
'97 d-90 axle housings ember For Sale - Parts 0 July 8th, 2004 11:52 PM
