Just failed an emissions test, suggestions? - Defender Source
Old October 8th, 2004, 02:53 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Carbon Monoxide was fine, but Hydrocarbons were a couple hundred PPM too high.
Pushing about 83,000 on the D-90.
Not too familiar with emissions stuff, suggestions?
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 8th, 2004, 02:57 PM
Are your cats ok? And run some Seafoam through the engine.
Old October 8th, 2004, 06:06 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Not an expert by any stretch of the mind, but when my friend's bronco II didn't pass his emissions test we ran higher octane gas for a tank. He passed the test the next day. Just a shot....
Old October 8th, 2004, 08:48 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Take a piece of cardboard the size of a shoebox and paint it black, then tape it to the front of the radiator. Drive around untill the water temp is semi-close to the red. Take it in to test, you will pass with flying colors. Then remove as fast as possible.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 9th, 2004, 01:14 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I don't know how close you are to passing but I would also suggest Seafoam and drive it hard for a few days at hight rpm. These engines are meant to be driven at highter rpm's but everybody seems to lug them including me, I have to remember to rev it up every once and awhile. Give it a shot. Good luck.
Old October 9th, 2004, 10:33 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Have heard that adding some denatured alcohol to the tank will also reduce emmissions. And running it HOT at the test helps too. Here's what goes around in the back of mind mind as the final solution: Find a garage that also has an associated test facility, get some cash in someone's palm and have them put that probe up the exhaust of a Honda Civic. Of course, I would never, ever do this. Never....
Old October 11th, 2004, 12:12 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Check the distributor centrifugal advance to make sure it is not stuck...also look at the vacuum advance and make sure that it is not blown. Have run into this a few times causing failed emissions.
Rob
Distributer air gap ScottYates Defender Technical Discussions 7 December 15th, 2006 02:46 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 09:46 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
