Just did an engine swap and now wont run... - Defender Source
Old March 2nd, 2009, 01:42 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
94 D90 Red HalfCab #741
I just installed a rebuilt 3.9L motor this weekend. I have everything hooked up the way it was when it came out. I cant get the new motor to turn over and I cant get it to build up oil pressure. we vented air out the upper oil cooler line and filled it with oil to try try to prime the system. I have fuel and spark to the plugs and the timing is set to as close to TDC as we could get it with it cranking. We did a compression test and it is putting out good compression.
it did fire up twice after a long crank, but idled very poorly. Now nothing.
Any ideas would be greatly appreciated.
Ryan
Old March 2nd, 2009, 01:47 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
The manual suggest packing the oil pump with vasoline to prime.
As for the non start rough idle... Is your maf sensor plugged in properly?, fuel pressure in rail? Getting spark? Timing? check all the usual suspects.
Old March 2nd, 2009, 01:50 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I had the same issue once when I managed to set the timing 180 degrees off. Might be worth checking.
Old March 2nd, 2009, 01:54 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
we already did that and it was 180 degress off. it started twice after we switched it around.
Ryan
is there a fail safe that prevents the motor from running when there is no oil pressure?
Old March 2nd, 2009, 02:26 PM
btate
Bryan Tate
d90
just to clarify. It is not turning over now?
Old March 2nd, 2009, 02:51 PM
No the truck will continue to run w/o oil pressure until it kills itself and blows up.
Old March 2nd, 2009, 08:41 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
yes, as of right now, it wont turn over. when it is cranking, it sounds like it wants to turn over.
everything appears to be hooked up properly. We labeled everything as we unhooked it, and it was only a week from when we pulled the old moter, and installed the newer one. We are getting plenty of fuel through the fuel rail. a couple leaky injectors was noticed so new O rings got installed. we have plenty of spark to the plugs. this morning we did a compression test and that checked out OK. We have triple checked are double check on the timing. We set it as close as we could when it we were cranking on it. and when it did fire up the , (in the 20 seconds that it ran) we checked it again. We are close enough to TDC to where it should be starting up. We were getting an arc across the terminals on the ignition coil, so a new one was installed.
That is pretty much up to date of where we are and everything that we have done. I didn't have much time to look at it today after my posts, but tomorrow I have open to spend some time with it.
Thanks again for everyones input on the subject.
Ryan
Old March 2nd, 2009, 09:12 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Cam Timing off, perhaps?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 2nd, 2009, 09:28 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Inertia switch? Spark plug wires hooked up correctly? Ground wires? Basically everything you unhooked needs to be rechecked
Old March 3rd, 2009, 09:18 AM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
when we put the cam and timing chain in, we alligned the pointer on the crank gear, with the mark on the cam gear.
Old March 3rd, 2009, 11:05 AM
Roadsiderob
Robert Dassler
1994 D90
Did you use a stock timing set with one keyway or the aftermarket adjustable type with 3 keyways? I'll admit to misreading the marks on the adjustable type once and ending up with a rebuilt engine that wouldn't start....
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 3rd, 2009, 11:40 AM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
I put in the stock timing set with only one keyway. its a new timing chain and new gears. All the new parts matched up just like the old ones. the compression test read 130 out of the cylinders. I could be wrong but I dont think it would build up that much compression is the cam timing was off.
Old March 3rd, 2009, 03:03 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
just wondering if there is anyone in the littleton area that might be able to come take a look and help diagnose the problem. Santa Fe and Belleview to be exact. Both my mechanic friends are getting a little frustated with why it wont start. My fridge is stocked with beer if anyone wants to hang out and try to help get my rig back on the road.
Cheers,
Ryan
Old March 3rd, 2009, 03:25 PM
btate
Bryan Tate
d90
Just a thought, make sure the distributor is connected correctly. One of the 4.6's we did this summer, we thought we had a bad distributor. When we looked closer we had connected it backwards.
I guess they were only "idiot resistant' vs "idiot proof"
Probably not your problem, but hated not to mention it....
And you did try the inertia switch?
Old March 3rd, 2009, 05:58 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
yep, finally got her running. all that diagnosing and it turned out to be a simple fix. we failed to adjust the gap in the spark plugs. It was about half of the recommendations from whats in my defender manual. once adjusted, fired right up and idles on its own now.
I am just glad it was an inexpensive fix. Thanks for everyones input the subject.
First round is on me!!
Old March 4th, 2009, 11:02 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Hey glad to hear you got it up and running. Where did you get your 3.9 from? While my engine is running solid right now it can't be for too much longer.
B
Old March 4th, 2009, 11:29 AM
landrovered
S. Smith
I had a similar experience after a valve job. It started but ran like crap. When I pulled the plugs they were not gapped properly. I was embarrased that I had not checked them before I put them in. Oh well that will never happen again. Lesson learned.
engine
