Just back from Dealer Purge ESR4222 - Defender Source
Old February 6th, 2009, 04:46 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Just came home from dealer had 3 codes P1179 said purge valve stuck open. Part # ESR4222, They want a small fortune for a new one Do I need it? Code 2 P0307 #7 cyclinder misfirethey said to start with plug and wire anything else? Code 3P1317 rough road signal permanetly at ground or open circuit where do I start there?
Old February 6th, 2009, 05:16 PM
I am afraid it is terminal. I will offer 10k cash to sell it to me.
Ron
Ok, is the CEL on all the time or was it just stored codes? If you have not done plugs in wires in 30k I would start with that for the misfire. See if that plug is noticably cleaner than the others.
As far as the charcoal canister fault code, I have not seen that often so I don't know what to say other than I think it is a D90 only part. You might be able to get a disco I part to fit but I kind of think not (ie it would be cheap used).
Rough road, search as it has been discussed frequently.
Old February 6th, 2009, 06:17 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
The D90 purge valve has a hard plastic line that is crimped on semi permanently- the Disco has what I am 99% sure is the SAME purge valve with the a short peice of rubber hose between the line and the valve.
I think the Disco part can be retrofitted, and plan on finding out real soon (well as soon as the part comes in).
Old February 6th, 2009, 06:28 PM
pcscharfe
pcdefender
D90/NAS 110
I also have P1179. I keep clearing the code and it keeps coming back.
Correct me if i am wrong.
CODE: P1179 is Maximum Negative AMFR (air mass flow rate) which has an incredbile number of potential causes: leaking exhaust, MAF sensor, fuel pressure issues (fuel filter, fuel pump)?
My cats are new and O2 sensors are supposedly all in working order.
How was the charcoal canister diagnosed on yours?
Anyone else diagnosis this issue? Saw one post here:
http://www.defendersource.com/forum/...eferrerid=1953
Old February 6th, 2009, 09:39 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
The guys at the Dealership (said) that was the problem. Who knows for sure
Old February 7th, 2009, 01:23 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up
I ask only because I am trying to diagnose the same problem and hopefully not get screwed by a mechanic in the process. Let us know if the charcol canister turns out to be the issue. Good luck!
Old February 9th, 2009, 08:09 AM
crown14's Avatar
crown14
Verticalscrote
part number for the Disco purge valve is ESR3980
Old February 9th, 2009, 08:31 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
ac
Purge Valve ESR4222 Hammertime Wanted 0 February 6th, 2009 03:48 PM
My vote for Worst LRNA Dealer Eric Siepmann Misc. Chit-Chat 10 March 19th, 2004 07:59 PM
Dealer in Conn? AggieD90 Misc. Chit-Chat 3 March 7th, 2004 10:35 PM
Back Door Rattle mdmccallum Defender Technical Discussions 7 December 19th, 2003 12:55 PM
