Just an FYI on starting & fueling issues - Defender Source
Old November 3rd, 2004, 04:15 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Yesterday, my truck died while in motion. Towed her in, went through a bunch of testing. Would run for a while and die again. Caught the fuel pressure at zero on one of the deaths. Switched out relays to f pump, still dying. Switched out ecu witha loaner, ran fine. Switched back, death. Somehow, yesterday morning, the replacement 95 disco ecu with the RPI chip i installed three months ago decided to start cutting power to the fuel pump at random moments.
Anyway, I still have the original ecu and running on that now. Moral: always good to have access to a back up ecu!
DW
Old November 4th, 2004, 05:34 PM
Doug's Avatar
Doug
Doug Walker
There is a Part Deux - an important discovery! I drove the truck with the original '93 ecu today, first time. ALL THE SYMPTOMS that I thought were caused by a bad valve train in the old 3.9 were present suddenly with the new engine!! 1. Fall off in power curve at 3400 rpm, 2. misfire at higher rpms under throttle. Also, since I now have an air/fuel monitor, I could see the mixture. Incredibly lean at high rpm, and lean misfire at idle!! ALL SOURCED from the ECU alone. I was stunned.
Can't wait to get a replacement ecu installed....
Anyone have a 95 Disco/Defender/RR 14CUX they want to sell?
DW
fuel, start, starting
300 Tdi Starting Issues discotdi Defender Technical Discussions 12 January 20th, 2009 11:04 PM
D90 starting issues - could it be Snorkel related? pmd Defender Technical Discussions 7 January 9th, 2009 12:47 PM
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
300tdi diesel fueling control solenoid Chris Cox For Sale - Parts 1 January 2nd, 2005 07:22 PM
Help With Starting My D90! Davis Defender Technical Discussions 0 September 7th, 2004 05:13 PM
